Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Wolfe Mini Tub kit?...
Old Jul 19, 2006 | 07:30 AM
Tom the roofer's Avatar
Originally Posted by ls1king000
Subcribing!!!
Only question I have is, are the adj. spring perches and springs a must?
I plan on a shortened rear by 2" total ( 1" per side)
off-set LCA's
adj. panhard
and 18x12 wheels
345/30/18 tires (d/r)
I know I was going to have to minitub but, I am really hoping to keep my hotchkis springs and koni sa.
With this said possiblity leaving stock spring/shock mount?
Yes you would need the spring perches and 2.5" springs because the Wolfe mini tub kit requires you to cut through the OEM spring perch. If you go to the Wolfe web site you will see a pic of this.
Old Jul 19, 2006 | 07:39 AM
Fireball's Avatar
This thread is great....I have my minitub kit and perches on the way
Old Jul 19, 2006 | 08:04 AM
Originally Posted by stressfulcar
You can't imagine how much help your write up has been. I'm in the process of doing a wolfe kit on my car,and your info has been invaluable.I've almost completed the driver side (tackled it first since it's the most difficult).Here's a few pics,and thanks for the info!
thanks man. I appriciate that. Your mini tub looks great dude. Yours is rusty like mine was. It will take some elbow grease to clean that up but it will clean up real nice. I must confess I talked my wife into doing this for me She's a trooper.
thanks Fireball
Old Jul 19, 2006 | 10:51 AM
Jon@Texas-Speed's Avatar
Awesome write-up! I finally have my kit on the way and should get started in the next week or so. What fuel cell did you end up going with? Also, you wouldn't happen to know what the body shop used to widen the fender? Do you think you could just roll the lip?
Old Jul 19, 2006 | 12:39 PM
Thanks Jon. I have an aluminum fuel cell "tank" in the OEM location and I still use the fill tube, thus leaving the hump in tact.
I believe the body man cut and rolled the lip. Not sure what he did on the plastic portion on the rear of the wheel well. I can't help you there.
Old Sep 27, 2006 | 01:33 PM
NA$TY-TA's Avatar
This is an awsome write-up
Old Sep 27, 2006 | 05:35 PM
oldschoolmuscle's Avatar
subscribing.
Old Apr 8, 2007 | 07:31 PM
JUICED96Z
Guest
Posts: n/a
Any finished pics?
Old Apr 9, 2007 | 05:14 AM
Originally Posted by JUICED96Z
Any finished pics?
I posted some inside finished pics above.
Old Apr 9, 2007 | 11:52 AM
Lurius's Avatar
Very nice!
-Lurius
Old Apr 9, 2007 | 02:52 PM
Justa Z's Avatar
humm... This makes me want to start cutting up my car again. I need a 29.5" tire Looks really good. Thanks for the write up
Old Apr 25, 2007 | 11:31 PM
  #32
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Glad someone bumped this. I couldn't quite remember where I had found this thread before. I plan on using this when I start hacking up on my car. I've already got the mini tubs, spring perches, hals, springs, offset LCAs, and some 325/50/15 ET street radials. Just need to get my camaro fixed, some more parts and I can get started.
One key point that I've noticed (which might be common sense) is that if you leave your minitubs unpainted or unoiled for a while they will begin to rust. They're only sheet metal and need to be protected. I've had mine inside for about 3 months now and they've developed some rust. Granted the fact that I live a block away from the beach might have something to do with it.
Old May 29, 2007 | 07:52 PM
  #33
slammed1500's Avatar
good job on the tubs and posting the steps it takes
i was going 2 be doing this and then i fount this write up and it made me feel a lil beter about doing it. i was scared about cutting the side of the spring pocket (thats part of the fram rail)
im going with a 20x10" wide wheel but with a 5" bs so i should have around a 5 3/4 - 6"lip on the wheel and i will have 2 narrow the rearend 3"
how much did u narrow the rearend
Old Nov 4, 2008 | 02:16 PM
  #34
ty_ty13's Avatar
7 Second Club
wow... i need this... subscribed.... i know many other guys are talking about this right now too....
Old Nov 4, 2008 | 03:41 PM
  #35
Big Bird WS6's Avatar
few questions,
first, if i go to a rear coil over do i need the spring perch?
second if i want to leave factory plastic in with out cuting it, is a mini tub worth it?
thrid if i don't narrow rear end but change back space will that be fine?(reason this way i can have wid track tire, and nice looking street tire)
finaly how big of tire will fit with BFH Mod?
Old Nov 4, 2008 | 03:59 PM
  #36
Hilton's Avatar
Tough Mudder
Outstanding! Love a mini tubbed car.
Old Nov 4, 2008 | 05:50 PM
  #37
Dwn Cam's Avatar
Priceless Tech Article.
