Video: Autozone's Air Conditioning Systems
I was in AZ yesterday getting some stuff for my 94Z, and saw this DVD for 7 bucks. Figured that (a) since I don't know much about air conditioning systems, and (b) I need to rework the A/C systems on a few cars I own, I'd pick it up and watch it. 7 bucks, what the heck.
Frankly, I thought it was pretty good. Worth the money. Shows all the parts, how they work together, and what pressure readings while doing diagnostics look like. Shows how to start up from an open system, and talks about the parts that need replacing. I knew a little about A/C systems before, but now I have a real good idea of where to start on getting my systems back up and running. Seems pretty straightforward now.
I give it 2 thumbs up. Production quality was decent, though it wasn't recorded in surround sound. Kinda reminded me of Sam and Dave's Shadetree Mechanic, only without the buddytalk and cussing.
Their demo vehicle was a Chevy pickup, looked like about a '96 model. They ended up replacing the compressor, the condensor, and the accumulator, as well as showing the orifice tube, how to clean out the evaporator, etc. Good stuff.
It ran right at an hour in length.
Yeah, I was about to just throw a new accumulator/dryer in my 94Z, pull a vacuum, and pump a few cans of R134a in it. Probably would have worked, but that's what I did last time, and it worked OK (just OK) for a while, and then started not working on me.
Now, I think I'm going to:
1) Replace all of the o-rings
2) Disassemble the lines and clean them out
3) Remove and drain the compressor of oil, and put new / fresh / the right amount of oil in there
4) Maybe put a new orifice tube / expansion valve assembly thing on there (it's $60+ tho). Heck, I didn't even know where it was on my 94Z... the video showed what it looked like, and I know exactly where / what it is now.
5) Pull a real good vacuum on it
6) Put a little flask of UV dye in the system before charging, for future troubleshooting assistance
I just wish I would have done this before I put the engine back in the car this past Thursday. I think I'll just get the motor running (the new 383), and then go through the A/C system one weekend.
The full title is AutoZone AC Repair and Service, with Bruce Bonebrake (he also runs http://www.batauto.com ).
Sorry, no rippin' DVD's around here. If you're at all interested in A/C repair, though, even as an education to protect yourself when you have it serviced by a shop - it's worth the 7 bucks. I've certainly wasted far more money on far less beneficial items...
I looked around online, and couldn't find it. Found mention of it as "winning an award", but other than that, don't see it for sale.
Only one warning: if you can't stand the slogan "Get in the Zone... Au-to-zone!". DO NOT WATCH THIS VIDEO. It's repeated ad nauseum throughout.
Originally Posted by Brains
An orifice tube 60 bucks? Is it cast in platinum or something? They are more like 20'ish. I replace it every time I open the system.
I ordered my tools yesterday. I ordered a gauge set that'll do R134a and R12 (since my '93 Suburban is still running R12, the main A/C in it is starting to get a little weak (has had no maintenance in at least 4-5 years), and I have a couple of cans of R12 on the shelf ). I'm also thinking about using that R12 substitute in the Fiero (and not 134a) - and in the 79Z some day.
I also ordered the cleaner gun (has a bottle and an air nozzle to shoot the cleaning fluid through the system), a couple quarts of cleaning fluid, a schrader valve remover (though I have a couple, they're cheap, and I tend to misplace them ), a UV leak detector kit, and a green O-ring set. Spent a little over $200 on tools.
I'm just hoping I can go from 1 car (err truck) with mediocre A/C to 3 cars with decent A/C. Too dang hot in central Texas to go without...
I bought the video last night and just watched it during my lunch hour. Very good video and very informative. I deff recomend it.
I think you are thinking about the accumulator. That sounds like the part by the firewall.
Cool, glad ya liked it.
Here's an (old) pic of my engine bay. #1 is the accumulator/dryer. #2 is the part I'm talking about. It's about 4" tall, 2" wide, 1" deep. Just a hunka aluminum with some 'stuff' in the middle. It bolts to something on the evap core area, and the hoses screw in to it.
Cool. Yah. One of those.
Just as an update, I did use the procedures outlined in that video, and my Fiero will flat out chill my a$$ now. Even with its 1985 R12 designed system, with 134a in there, it gets cold.
I flushed everything with the special A/C flush fluid really well, put it all back together with the green o-rings, new orifice tube, new accumulator, pulled a vacuum, and then put in the 134a. This was a month or so ago, still cooling well.
Still have to tackle the system in my 94Z. Same procedure will apply, though I may not flush the system as it isn't contaminated.
