Sunpro Tach - lead wire location on ECU???
I bought a cheapy Sunpro Tach strictly for the shift light.
I only need someone to tell me which wire on the ECU I am supposed to tap into.
I can do the rest. I have been researching for several hours now and I cant find a direct answer for the LS1 F-Body.
2001 Trans Am 6 speed.
Thanks for all your help!!
Here's a link to a 2001 PCM Pinout chart.
If I remeber correctly it will be a white wire. Pin #10 on the red PCM connector.
Originally Posted by Dragon-LS1
Thank you. I saw that once before, but I was worried that the 98-99 LS1's were differently set up than the 2001. But that was the exact same pin# and color. Thanks a lot man!!!
99 to 02 fbody use the same pinouts.. only diff are adds and deletes.. (example: later cars dont have EGR, so theres nothing in the EGR pin locations.)
98 is the odd duck.
98 is the odd duck.
98 is the odd duck.
Thanks.
theres also a green wire on the connector that goes into the coil packs that you can tap into... if you dont wanna go to the PCM. I used this for my window switch, and it worked great.
Sorry.. still new to all this.
