piston notching tool
https://ls1tech.com/forums/generation-iii-internal-engine/457856-homegrown-flycutting-results.html
https://ls1tech.com/forums/showthread.php?t=457856
yeah, but it's 150 with a 300 deposit.
I chipped one cutter by having to small of a pilot shaft. It was drilled out bigger on the head I borrowed and did not know this. The tool jumped around a bit causing the cutter to chip the teeth off.
Just a little insight.
