Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Tool Help
Old Mar 11, 2007 | 08:12 PM
2002 Trans Am's Avatar
Default Tool Help
Would this cover pretty much every bolt on an F-Body?
http://buy1.snapon.com/catalog/item....re&dir=catalog
Contemplating this purchase. I'll be getting a 1/2" Snap On cordless impact and figured I could use an adapter to attach these
Old Mar 11, 2007 | 08:17 PM
BTW it is missing a 20mm and a 21mm
I already added a 21MM to cart because I believe that is the bolt size for the panhard rod and LCAs
Old Mar 11, 2007 | 08:47 PM
patgizz's Avatar
not sure you'll need a 20 but might be good to get it anyway to round out the set.
a majority of stuff on any metric bolted gm i've ever worked on has been 7, 8, 10, 13, 15, and 18. with some odds and ends interspersed in there.
Old Mar 11, 2007 | 08:51 PM
I'm concerned about the semi-deep. There is nothing that pisses me off more than not having a socket that is deep enough
Old Mar 15, 2007 | 12:04 AM
Lurius's Avatar
2x
I hate having to get back up and find a bigger socket, then upon realizing I dont own correct socket having to get an adapter to use 1/2" or 3/8" instead of whatever I was using.
-Lurius
