Aircraft Techs inside
Any of you guys have any advice on starter tools that I should get beyoned the basic screwdrivers and stuff that you have found handey?
Looks like I start 4:30pm to 3am, not sure on the days yet. Optional overtime, free uniforms and unlimited dry cleaning for them, building is fully climate controlled and all work is done inside, nothing is done outside.
If you will be doing any disassembly or reassembly of the aircraft, go to Lowes and get the BOSCH LI-Ion pocket driver. It's about $120. That's probably the best money I ever bought since I'm constantly taking screws in and out. (Don't buy the big 18 Volt monsters) Also, get one of Snap On's wobble screwdriver bits. They are $6 but well worth it especially if used in a snap on ratcheting screwdriver. For screws in almost impossible places to get to, use a 1/4" ratcheting box wrench and a #2 bit. You will need to put a little bit of .032" wire around the bit to keep it from popping on through the wrench. Buy a can of CLOVER brand valve lapping compound. Dab a little on the screwdriver tip, and you remove almost every single screw that refused to budge and almost strips out. IT's a real life saver. Once you try it, you will be a believer.
For power tools, don't cheap out, and lighter is ALWAYS better.
For tin snips, get an offset snip. I would get a nipper too since they are relatively cheap.
browntool.com
yardstore.com
The company provides everything over an inch (sockets, wrenches, ect ect) and all the expensive stuff. Pretty sure they have the drills and all also.
Good idea on the screw driver. I have a cheap-o one and love it.
I wanted to take pictures of this place but security said no.......... would have no idea why......retarted.
. 1/4" Drive Socket Set, 3/8" Drive Socket Set
#1,#2,#3 Phillips Screwdrivers
Combo Wrench Set 1/4" to 1"
Safety Wire Pliers, Meedle nose pliers,Diagonal pliers Duck Bill Pliers
Channel locks
Flashlight
Punch and Chiesel Set
Ball Peen Hammer
Assorted Files
Utility Knife,Tre Air Chuck
Air Blow Gun
Hex Wrench Set
Inspection Mirror
Magnet
Assorted SLot Screw Drivers
Scribe Set
Putty Knife
Speed Handle
Tote Tray
Easy out Set
Soft Mallet
Tape Measure
Hacksaw,Awl,Wire Brush
Ignition Wrench Set
Rivet Cutter,Cleco Pliers
That should get you started $.025
I think I will like sheetmetal, only time will tell.
What we have right now is a Southwest 737 or two, we have a FedEx 727 and a Northwest long body (can't remember the make). All under heavy checks.
In a few months two hangars (can fit two 737's) will no longer be used for storage and will start having planes in them. I think they said one will be DC-10 only.
From the 2nd to the 8th I am in company training. After that they stick me on an airframe.
What did most of you guys start out at?
As a student they are starting me at 13.50 an hour and fromt what I heard its another .60 every 6 months for like a year or so. No A&P or anything.
I figure once I get that I should move up a good chunk?
Saftey wire pliers are my best friend
I know come this summer once I get my A&P I will be able to make a lot more but as a student I can't complain.
Did you just get out of school/graduate? How long before you can write your exams?
I had most my time in 727's real workhorses. L1011 were awsome bird. The 737's reminded me of gocarts real cool except when you under them changing the A/c machine.
So I take it you are going to do "C" checks.
They came with the hangar when AAR bought it.
Just stick to the basic hand tools till you find out what you will be doing. You will more than likely be stuck in **** jobs for being a new hire.
Pulling cargo pit panels. Removing galleys and shiters, pullings seats and interiors. All no fun for just starting out. If you are lucky you might end up on a sheet metal crew, in that case a high speed will become your best friend. Plan on grinding and cleaning a lot of corrosion. Just because they say sheet metal dose not mean you will be doing sheet metal. Once your in the door, and on the floor things change.
You may ask how I know, I have been in the field for sense 1985 been with 3 major airlines, gone through my share of lay offs, pay cuts and bankruptcy's and loss of a pension.
I am not trying to scare you or talk down to you, by any means. In this day and age the industry has changed a 180. Just be ready to have a back up plan because things can change over night. You think you have it good, then they sell the rug out from under you.
Be cautious, it is going to be a rough road. I am sure there are more that can tell you the same and or other things to watch out for.
Chris
Not sure if I want to stay working on airplanes my entire working life.
Were I work at now has A TON of backstabing. Happens every day. I have just learned to avoid it the best I can and when you get screwed you just move on.
My goal is to one day get out of the hangar and work the line.
Yep lots of C checks. We have a Southwest 737 thats COMPLETLY gutted right now, no floor, no engines, nothing lol.
I will be taking my tests late this year. My last class engs in August but will not be able to test untill the end of the year. I am kinda glad thats the way it will happen because I am REALLY lacking in the studying department.
Ski
My old man just got back from a live fire in FL (F-16 crew chief) and they could not even aford planes to fly them down or a SINGLE 130 for the equipment. Or even charter buses so they had to rent like 20 mini cans and a few semis and had to drive down and back.......
All the money is going to the war so what can you do lol.
Chris
If you get a ******* job run, run as fast as you can!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You will love working on the line. Theres always action if you know what I mean.
Quick tip for when your on the line. If you endup on a night departure shine your maglite at the A/C after it has boarded, and start pointing while you talk to someone. Then shrug your shoulders and wave it off like it was nothing.
LOL!!!!!!! I have heard stories of guys coming out to the jet and the tech is looking at something in the engine and the lead starts yelling at him. The guy hands the lead a handfull of bolts and assorted items and they both look around and then wave at the pilot and smile.
Knew another guy that went up to a pilot after an engine swap and said "here are some extra bolts that came out but we could not find were they went when we hung the engine"
