Where can I get a good oil drain pan?
11Second Club
Hey all,
I use this oil pan, and the design is pretty decent, but the problem is that it's just a crappy piece of plastic. It leaks, and the plug that goes in the middle on the top doesn't even stay in place. If I could find a quality, metal version of this, I would be ecstatic. Show me what you use!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
11Second Club
Which one am I supposed to be looking at? The galvanized pan with the open top? The one I have can be closed up. If the stupid thing was made well, I could throw it in the back of the pickup and take it to AutoZone without worrying about it spilling.
6 & 8 Second Club
They have a galvanized pan at most of the big chains around here. It holds enough to do my diesels (~4 gallons) I love it, strong and stable when full. I have old fuel barrels as drains (55 gal) so I don't have to transport. If you need to move, I would get a 5 gallon gas can, and use that for oil only to recycle.
Thanks from me & my family for being intelligent enough to recycle. Too many lazy ***' drop it into the ground or sewer.
PT's Slowest Truck
I have the same one that you do Gauge, actually I'm on my 2nd one. The first one did the same things that you mentioned. I also have another plastic one that's a little smaller and compact...it's rectangular shaped and I've had it about 10 years. It's great because I can slide it under my wife's Toyota Matrix w/o even jacking the car up. Unfortunately, I haven't seen that one at the stores anywhere any more
It would be nice to find one made of metal like you mentioned though, instead of replacing my other one every few years.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
11Second Club
Just FYI, the guys at Auto Zone tell me that they don't truly recycle old oil. They take it up north and burn it in furnaces specifically made to burn the stuff.
11Second Club
Originally Posted by budhayes3
I have the same one that you do Gauge, actually I'm on my 2nd one. The first one did the same things that you mentioned... It would be nice to find one made of metal like you mentioned though, instead of replacing my other one every few years.
