Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Air Conditioner Vacuum Pumps
Old Jun 5, 2007 | 01:49 AM
2KThunder's Avatar
Default Air Conditioner Vacuum Pumps
Does anyone know if any places rent automotive vacuum pumps or anyone ever done it? Ive tried a few places and they act like im crazy. I cant afford $300 for something ill use once. Any ideas?
Old Jun 5, 2007 | 11:49 AM
G-Body's Avatar
sawzall wielding director
If you have a big aircompressor you can buy a venturi vacuum pump. They should be under $50, but they do consume a lot of CFM of air.
Old Jun 5, 2007 | 11:53 AM
ghettocruiser's Avatar
Autozone SHOULD rent them. I say should, because most stores dont carry them. My store didnt, and I saw that we had them for rent. So a customer asked where to get one, and I said Ill order it and rent it to you. After that, it stayed in our store. Problem is, half the idiots that work at autozone dont know what they heck they are doing. So many resources at that place that no one knows how to tap.
Give them a call and ask. I havent worked there in almost 2 years, so things may have changed, but I know Ive rented them out before...
Justin
Old Jun 5, 2007 | 01:07 PM
2KThunder's Avatar
Yeah I saw harborfreight had a Venturi one for cheap, I just dont think our compressor could handle it. I mean the specs match up, its got a huge tank I just dont think it can pull, it seems when using just air tools it emptys fast, and Ive heard the venturi pumps take a bit longer.
Thanks for input thus far
Old Jun 9, 2007 | 12:02 AM
gto69judge's Avatar
Default Make Your own
I have used old refrigerator compressors as a vacuum pump for over 30 years. They will pull at least 28" of vacuum which is plenty for A/C work.
You can purchase a port to solder onto the 1/4" or 3/8" suction side of the compressor from any heating/cooling supply house.
Old Jun 13, 2007 | 10:40 PM
theblur98ss's Avatar
If you just want to recharge your system try any hvac shop in the area. Have them pull the vacuum and then you can do the rest. Shouldn't cost very much.
Old Jun 16, 2007 | 08:27 PM
MikeGyver's Avatar
Most HVAC shops will not have the adapters needed to hook up to modern automotive A/C fittings.
Old Jun 28, 2007 | 08:41 PM
Hugger's Avatar
You are going to laugh... but I use a hand operated vacuum pump with and HVAC adapter on it. Your hand will get tired pretty quick but it will pull a vacuum. I am really cheap! I have done this twice now without any problems... other than a cramped hand!
Old Jun 29, 2007 | 04:07 PM
MikeGyver's Avatar
What is a hand-operated vacuum pump? Got pics?
Old Jun 29, 2007 | 10:01 PM
Camaroholic's Avatar
MityVac is one. http://www.mityvac.com/
I use a Venturi pump run off the air compressor. Works fine for me.
