Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Harmonic Balancer Puller
Old Jul 26, 2007 | 08:37 PM
FRCBobby's Avatar
Default Harmonic Balancer Puller
Needing a harmonic balancer puller. The old 3 jaw has had it. Got a few upcoming cam installs to do and figure I might as well go ahead and get one on order.
One that I could find local would be great. Auto Zone, Advance, NAPA, etc..
Thanks
Old Jul 26, 2007 | 09:03 PM
FRCBobby's Avatar
Will this one work??
http://www.napaonline.com/MasterPage...alancer+Puller
Old Jul 26, 2007 | 10:43 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I just rent them when I need them from AutoZone. It only ends up costing the tax that gets rung up with it.
The one you listed looks like the late model Chrysler harmonic balancer puller, which will work fine on an underdrive pulley, but I'm pretty sure it wouldn't be big enough for a stock (7.5") diameter pulley.
Old Jul 26, 2007 | 11:25 PM
ERIK@MASPORT's Avatar
Closed Sponsor Account
Yeah, just rent it man....the 3 jaw pullers work well on the stock crank pulleys....it is the aftermarket pulleys that sometimes get tricky...
Good luck!
Erik
Old Jul 27, 2007 | 04:18 AM
FRCBobby's Avatar
The next few I will be pulling are stock pulleys. So any suggestions would be great.
I have to drive about 45 minutes to get to an Auto Zone so I would prefer to just go ahead and buy one so I will have it if I need one. Link me to a recommendation if possible guys. Thanks.
Old Jul 27, 2007 | 08:04 AM
DRCE's Avatar
I have one that is an installer/remover that I bought. In fact I did the R&D for their LS1 shaft. It works damn well. I will post up the name of the company later. It escapes me at this time.
Old Jul 30, 2007 | 12:19 PM
FRCBobby's Avatar
Ended up picking up the Posi Lock at Sears so we will see how it works.
Old Jan 1, 2008 | 08:19 PM
oreowizard's Avatar
The one that I rented wasn't long enuf to reach into the crank, what's the deal. I got one from Auto Zone and CANT get it to work. Any help would be GREATLY appreciated
Old Jan 1, 2008 | 09:08 PM
vette#3's Avatar
i bought a 3 jaw puller from advanced on sale for 10.00 this is what i use ,i have no problems pulling harmonic balancer pulleys with it maybe u have it on backwards Look @ the red puller ,this is exactly How it goes
Old Jan 3, 2008 | 10:30 PM
craze4speed's Avatar
ive got a snap on paid around $100
Old Jan 4, 2008 | 12:41 AM
Mean Green z28's Avatar
I've got the SnapOn GM balancer puller too and it's a LOT easier to use than the usual 3 jaw gazillion piece pullers available at regular stores. The regular pullers are longer and give you no space to even use an impact wrench on it 'cos it hits the radiator. The one I have is the same as this ... http://www.closeout.com/we-otc-6267.html ... ofcourse, I paid more 'cos I bought it from the SnapOn truck ...
Old Jan 4, 2008 | 08:24 AM
FRCBobby's Avatar
i ended up picking up the Posi Lock from Sears and it works like a charm.
Old Jan 5, 2008 | 04:30 PM
CarnivorWS.6-01's Avatar
Use a 6" 3/8 extension that is what I did. Improvise!!!!
