Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Garage floor coatings
Old Sep 8, 2007 | 03:47 AM
mook99ta's Avatar
Default Garage floor coatings
Looking to coat my garage floor with either epoxy coating or something of that nature or some checkered tile. What are you guys using and whats the best for oil spills and easy to clean up?
Old Sep 8, 2007 | 06:34 PM
ponjohn's Avatar
http://www.budgetbob.50megs.com/ANY2...ORESALENOW.htm
Old Sep 8, 2007 | 08:16 PM
pnhigg's Avatar
I love my epoxy shield flooring.
I haven't spilled anything that has seemed to effect it, with the exception of brake fluid.
Very easy to clean, looks great.
Old Sep 10, 2007 | 07:21 AM
'00_Z's Avatar
Anyone else using these products, I may be doing this in the spring.
Old Sep 10, 2007 | 09:12 AM
njc.corp's Avatar
looks good-it says he ships international-will be looking into this for sure-
Thanks for the find boy's-
Old Sep 25, 2007 | 07:35 PM
SSJIMMY's Avatar
my Dad has epoxy in his shop and it holds up great plenty of oil and grease has been on that floor and in the same spot and it still looks like new.
Old Sep 26, 2007 | 04:30 AM
mook99ta's Avatar
What kind of epoxy Jimmy. I saw some kits at home depot and lowes for like 60-80 bucks that don't seem bad just never heard of anyone using them.
Old Sep 27, 2007 | 09:42 PM
Ryan K's Avatar
Pathological Modifier
Biggest thing you have to lookout for in Epoxy is that you need to stay away from water based products. Solvent based are better at avoiding stains from automotive fluids.
Ryan K.
Old Sep 28, 2007 | 11:18 AM
1fastWS6's Avatar
I used the Epoxy Shield from Lowe's in my new house. Takes about 3 gallons to do a 3 car garage. Good prep is important obviously which is why I did mine right away when the concrete was new. But that stuff is awesome, very scratch resistant dragging a floor jack across it. I've spilled gas, oil, brake fluid, etc. on it and it still looks perfect. Highly recommend that stuff.
Craig
Old Sep 28, 2007 | 11:52 AM
SIK02SS's Avatar
other problem with epoxy is after some time it turns yellow. i went with these guys: http://premiergarage.com/httpdocs/index.html and love it
Old Sep 28, 2007 | 02:27 PM
Fastbird93's Avatar
I sent him an email asking some questions about prep and such, and his reply to me was that prep is important, but that the solid state epoxy is much more forgiving than the other mainstream stuff out there. I may give this stuff a shot as soon as I get my motor swap finished up. I like the idea of the solid rather than diluted epoxy.
Premier Garage -- VERY nice stuff, well done, guaranteed, but wanted $3K to do my 750 SF 3 Car garage. That's a forged shortblock (almost), so I said no thanks.
Old Oct 2, 2007 | 05:21 PM
pddye's Avatar
Here at my store we sell the rustoleum kits. Our village used the tan kits in their water pumping station and it worked out great. Just make sure you don't have a water problem. Take a piece of plastic 2' x 2' and tape it to the floor. If the plastic condensates in a week or two then the epoxy will eventually pop after a while. Other then that good surface prep and your ready to go.
Old Oct 4, 2007 | 04:04 AM
mook99ta's Avatar
Craig
Do you have any pics?
Old Oct 5, 2007 | 09:05 AM
1fastWS6's Avatar
Here's one, not real great though.
Craig
Old Oct 5, 2007 | 09:18 AM
chromeplated500's Avatar
I've been having problems getting the epoxy to stick... Ive used acid cleaner and everything to prep the surface??? any ideas?
Old Oct 12, 2007 | 10:50 AM
1FSTLS1's Avatar
I cheaped out and used the crap from Home Depot. On a 20 year old floor it held up great. Did a few burnouts bu accidedt and it came up a little. Sure make cleaning things up eaisy and looks great. Cost me less than $100. Would I use it again. Yup.
Old Oct 12, 2007 | 11:48 AM
SIK02SS's Avatar
yea, its def not cheap...but thefinal product and customer service you get..2nd to none
they also gave us a nice discount due to the size of it and them really wanting the job (not out of desperation...just to show finished pics of to future customers)
Old Oct 12, 2007 | 11:51 AM
SIK02SS's Avatar
only thing i can think of is that maybe not all the acid was washed out thoroughly enough and some adhered to the asphalt which is now causing it to not stick well?
prep is very important. they spent almost a full day and a half prepping ours with a dozen man crew
Old Nov 7, 2007 | 08:28 PM
slayer_taunu's Avatar
i used u-coat-it. was kinda expensive, but i like the result. some advice i can give is to go nuts with the surface prep... in some of the areas that i coudlnt get off all the **** that the previous owner spilled, the floor is a little discolored (but still sticks fine). also, it tells you to 'mist' the floor with water before the first coat. my floor isnt perfectly flat in all areas, and water pooled a little in some areas... that caused the first layer to be a little thin in those areas. luckily they arent in an area where i'm going to drive over or be likely to spill chemicals, but its still important to note.
Old Nov 9, 2007 | 09:03 AM
plopp's Avatar
I used the HomeDepot stuff for $25 a gallon, "battleship grey".... I think the brand is Behr... it held up very well for the price, I am glad I didn't spend $200 for this because I am welding a lot in my garage and I painted a car in it last year.... time for a second coat of that cheap Homedepot epoxy
