Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Tacking aluminum with Mig
Old Sep 29, 2007 | 09:00 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Default Tacking aluminum with Mig
Is there any way to just tack aluminum with a mig using aluminum wire without blowing through?
Old Sep 30, 2007 | 08:35 PM
nandofabricado's Avatar
not really just use a sharpie and blue painters tape (masking tape)
Old Sep 30, 2007 | 08:42 PM
CTSmechanic's Avatar
Depends on the thickness of the material as well as the amperage range oh the machine. If I have to tack something using a TIG I clamp a piece of angle or flay steel behind it and it works ok I would think it would also work with a decent mig
Old Sep 30, 2007 | 09:05 PM
xfactor_pitbulls's Avatar
The problem you run into using wire to tack aluminum is the lack of heat. You need to have a pool for a few seconds to get any heat out of it. Just depends on how strong you need it to be.
Old Sep 30, 2007 | 09:43 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
just strong enough to survive a few minute drive to the welders to finish the weld with his tig.
Old Oct 1, 2007 | 12:00 PM
1fastWS6's Avatar
Just tape it.......it'll be too much of a hassle with a MIG. I just sold my spool gun, even with that a MIG on alum. is very finicky and if it's not perfectly clean you'll just blow a hole in it (assuming your wire doesn't ball up on you first). Either way I think you'll just end up with a mess on your hands.
Old Oct 9, 2007 | 10:11 AM
jus1975's Avatar
Is it possible to weld aluminum with a MIG. I have a licoln 140 and wanted to buy a spool gun to weld aluminum.
Old Oct 9, 2007 | 10:30 AM
1fastWS6's Avatar
If you have a new 140T, 140C or 180 machine you can get a spool gun for it for about $180 on Ebay. I just sold the one I bought for my 180 machine because I bought a TIG for alum. The MIG works ok, but not near as nice as TIG. Plus you won't be able to do very thick alum. with only a 140 machine.....maybe 1/8".
Craig
Old Oct 13, 2007 | 03:34 PM
Phil99vette's Avatar
7 Second Club
I usually tape mine and pull 2" back and tack. Once I get the inital tack done I'll remove the tape to make sure the fitment is still dead nuts. Before you tack, make sure its been Stainless brushed, acetone'd and ready to go.
