Air Compressors - Information please
Which is better, a higher PSI rating (150psi vs 175psi), or a larger tank capacity? Which is more important to look for?
Any brands to avoid? Recommend?
What is a decent sized home unit, good for working on cars?
Tony
Depending on how much you want to spend there are a number of good ones out there. A trip through Lowes or Home Depot might be worth while. Anything that has the Dewalt or Porter Cable name on it is good, but made out of gold. For the most part they are all going to be very similar.
well, but many tools are volume hogs. Especially
sanders/grinders and sandblasting. Horsepower
(minus waste) equals flow*pressure. I got a
big-*** upright Craftsman oilless and, yeah,
it makes some noise, but I hardly ever run it -
just live off the tank mostly. But a die grinder
will run it down. It turned on twice while I
ported two exhaust manifolds.
Don't overlook the hose and connectors. If you
use quick-connects, look at the way it chokes
the line - and hard-plumb one end of it. Forget
1/4" hose, going to 3/8" hose costs little but
gives you "free horsepower". For distribution I
have 3/4" iron pipe inside and outside the
garage. PVC is on borrowed time when you run
high pressure air/oil through it.
I like this new forum.
John
Tony
I've used the heck out of it.
Porting heads, throttle bodies, grinding calipers, inflating tires, painting, etc.It keeps up with the tools OK, but the HVLP spray gun really put the tax on it. It really didn't support enough CFM to keep up with it.
Of course, I bought it 7 years ago, so it's been worth $300 to me.
-Andrew
PSI is perfect, but 30 gallons is not enough VOLUME for blasting, painting. Next time I'd look for an upright which will save some space.
Nobody uses a 3/8 gun too much but this is a good deal Don't u think
Here is a link that might help you out Tony.
http://www.porter-cable.com/index.asp?e=547&p=2580
This is mine.
http://www.porter-cable.com/index.asp?e=547&p=2589http://www.sears.com/sr/product/deta...S&bidsite=
Out the door with 50 ft of 1/2 in air hose and some fittings was 470. It is oil less and its not noisey at all....but im comparing it to the IR gas powered compressor at work, its not noisey enouh to bother me . I used it all day today tearing out a clutch and a brake job and it only came on twice. All and all im hapy with it.
brad
I've also heard that Husky's compressors are make by ingersal-rand, but I have no proof, if that's worth anything to you.
Sams club seems to have some good compressors lately also, if I had to buy another one I'd get it there and save a few $.
On the up side I actually wore out the piston ring and cylinder and it cost about 10 dollars in parts and it is just like new.
