Is Oxygen/mapp enough? or do i need.....
More or less, Im trying to seperate my exhuast... 3 inch td slip fit, from the header. It was slip fit, and standard exhuast clamp, so its bent a tiny bit on. I have the exhuast clamps off, but i cannot seperate the slip fit. I was told oxy Aceteleyene, get it red hot, and pull it off. Well doing some reasearch i came across the benzomatic mapp/oxygen torch kit which claims can get as hot as 5300F, ive seen alot of websites say Oxy Aceteleyene gets as hot as 4900, and some say 5700. Im wondering if i can get the mapp/oxygen setup, save a little money, it seems mapp is alos safer, cheaper, and easier to get, and can get almost as hot.
Is this the best way of getting the slip fit apart? If this doesn't work, im going to cut it off past the header. I tried heating it a little with propane today, but that just wasn't enough.
Thanks in advance, Chris
