A good shop press that isn't too large (dimnesion wise)
Harbor Frieght sells one cheap or you can make one with a bottle jack and I beam stock if you have a welder and a torch. The reason I don't have one is because they take up a lot of space for how often I use them. The local Air Base shop has one I can use for peanuts also.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Anybody know what force rating I'd need to
easily get the bushings pressed out a pair
of LCAs? My 6" bench vise won't budge 'em![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
So I guess rather than pay a machine shop I'd
rather go shopping at the HF store. I don't
want to buy a halfway-good-enough toy, but
benchtop is better than floor model when your
shed and garage are full....
Moderator
OK, I went and bought the 12-ton upright since
the HF store had no benchtops, and it's more than
enough to press out LCA bushings. The first one
was toughest as I didn't have any sockets that
were the right diameter to use, but after that I
sacrificed an old bushing for its shell and used
that for pressing out the rest.
The 12-ton was on sale for $99.
I got a 20 ton from Harbor Freight.Takes up vrey liitle space and it's light enough I can get it out of the way if I want to move it.
