Race Ramps For Lowered Vehicles!
Do you have a lowered car that makes it really difficult to drive up on ramps?
Tired of using pieces of wood to try and get your car up on the ramps only to have the ramps slide out of the way?
Here's your solution!!
67 Inch XT Race Ramps
Race Ramps 67 inch XT models are constructed specifically for use with even lower ground clearance cars! They are lightweight but strong and can hold up to 3000 lbs. Built in one solid piece they are durable and strudy and can work on any level surface.
Features:
* 100% Solid on all Planes. Solid Core
* 10.69 degree approach angle!
* Will not damage your hot asphalt, cement, or painted floors
* Will absolutely not slide on any surface
* Will accommodate tires 12” wide
* Hold up to 3000 pounds per set
* Gets your vehicle up even higher (10")
* Only thirty pounds per set
![](https://www.fasttoys.net/shop/images/raceramps67.jpg)
![](https://www.fasttoys.net/shop/images/raceramps672.jpg)
These are on sale right now for 268.99
We also have a 56" version (for cars not as low) for 186.99
Check out our full line of ramp products at:
http://fasttoys.net/shop/index.php?cPath=800
Features:
A proprietary solid rubber/foamish/plastic like compound. No slipping on the pavement!
They are quite light but very strong. They also will not scratch your driveway, garage floor or your car. They won SEMA product of the year with these.
6 & 8 Second Club
?? is the trax jax what I would use on my Pro-Mod. Will it clear an extended nose, 3" height. I seen a few of the pro guys using something. I'm cheap, I usually just take the nose off to get a jack under.
6 & 8 Second Club
Just a jack, so when I'm alone & can't get nose off, I can at least do something. My shop floor is very smooth & wood does slide once in awhile.
I have a set of the Race ramps for my C6 and SRT8 Charger...they work great, are light weight and don't slide a bit when driven up on. I feel alot more comfortable under the car with these than with the hard plastic hollow ramps from the parts store, and I don't scrape the air dams or the front valance driving onto them. I've recouped the money spent already on self oil changes and exhaust install in my driveway.
Tough Mudder
I'll ask the question everyone is thinking.
Why are they so expensive? Rhino ramps are ~$30. Sure they're half the length, so less material, but an additional ~ $230? No way. $100 a pair? Sure, put me down for a set.
I have the FTRA, and I recommend it to people, so I obviously support you, but not in this instance.
However, they did come up with a less expensive model for people that don't need the super low incline. They are called the Sport Ramps. They sell for a more reasonable 133.99 . Here is the link to those ones:
http://fasttoys.net/shop/product_inf...oducts_id=1558
The 67 XT's are still the most popular model as they combine a very low incline angle, wide track width (for wide tires) and non slip design that makes them perfect for Corvettes, Vipers, Ford GT's etc. Just about any car can get up these models without touching the front end of the car.
