Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
grinding on weld
Old Mar 1, 2008 | 10:34 AM
B18CYA's Avatar
Default grinding on weld
Just wondering what you guys use to grind excess weld material off?
Old Mar 1, 2008 | 12:15 PM
BADD SS's Avatar
in what application?
Old Mar 1, 2008 | 12:23 PM
B18CYA's Avatar
like grinding off excess weld material 409 stainless rod
Old Mar 1, 2008 | 12:31 PM
B18CYA's Avatar
these dont do ****
Old Mar 1, 2008 | 12:32 PM
s10blaza's Avatar
flap disc :dunno:
Old Mar 1, 2008 | 01:01 PM
Drew04GTO's Avatar
Wow, that burr isn't doing anything? I don't think I've ever come across something my carbide burr couldn't cut. Is that one high speed steel or carbide? How many times have you used it? Is it something no name from a local hardware store or a tooling company?
You might just want to try a fiber wheel, they'll cut even the hardest of materials, might wear out fast but they're cheap.
Old Mar 1, 2008 | 01:10 PM
RAGENZ28's Avatar
Angle grinder or a sanding disk to clean it up if you want it smooth.
Old Mar 1, 2008 | 02:36 PM
B18CYA's Avatar
turns out that burr isnt carbide. just got some carbide ones and they work great!
Old Mar 1, 2008 | 05:21 PM
BADD SS's Avatar
If your doing alot of work, or anything larger then a rod, I prefer Flap Discs, they are the do-all in my shop, I love them.... Seriously, they cut fast, last long and provide a smooth finish..
Old Mar 2, 2008 | 07:01 PM
greg campbell's Avatar
B18CYA,
They do make special grinding discs for stainless steel. Most welding supply stores will carry them. The company I use is called PFERD, they are made in Germany and last a long time. They also make aluminum oxide type discs for mild steel and aluminum. Mild Steel discs don't work as good because stainless contains a lot of chromium and nickel. This combination of metals make it extremely hard. You could then clean up the area with flapper discs as the others have suggested.
Old Mar 3, 2008 | 08:13 PM
ScramingYellowZonker's Avatar
Flap disc or a grinding wheel. sometimes 50 grit sand disc.
Old Mar 18, 2008 | 07:52 PM
01ssreda4's Avatar
i use a 6 inch flap disc at work called a charger, i fell in love with it the first time i used it. very smooth finish.
Old Mar 28, 2008 | 11:13 AM
rjsupply's Avatar
Thumbs up
For High Quality Carbide Burs that are made in usa, try rjtool.com
Here is a link to their Carbide Burrs:
http://www.rjtool.com/c-42-carbide-burs.aspx
