Dial Calipers
http://buy1.snapon.com/catalog/item....re&dir=catalog
Mine from HF:
Aside from the color of the ruler face, the similarities are striking!
Mine from HF:
I dont know if all metering dials and mechanisms are created equal, Im sure thats not the case. whatever you choose to buy, before you buy it, take it and measure for looseness in the calipers. bring a set of feeler gauges to the store. measure the thickness of the gauge with the tips of the calipers, and then move the gauge down into the base of the caliper jaws and measure again. compare the results; if you have any difference in measurements then the caliper jaws/mechanism is deflecting when pressure is applied. I went through two of em at HF and my third was built a little tighter.
