new impact, break in etc questions
So I'm wondering if I need to do anything special to break it in. I took it somewhat apart to look for grease, and there was grease in it. I also put 10 drops or so of mobil 1 5/30 in the intake for good measure. Is there anything else I should do before I use it? I have 25' of 3/4" od hose I think it is I had bought for a cheap gun, I coupled it permanent right to the new gun, no quick release. Should I cut the hose shorter for any reason? Do I need any kind of break in procedure? If I lube it each use with mobil 1 will that be sufficient lube? Any other suggestions?
here's the gun I bought...
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=009
