Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Finishing aluminum
Old Apr 29, 2008 | 05:41 PM
Phil99vette's Avatar
7 Second Club
Default Finishing aluminum
Looking for some options for finishing aluminum. I've got a couple parts we've welded and need to finish. I've seen a couple guys strip the aluminum with easy off oven cleaner and polish them but I hate keeping up with polished parts. Any other good solutions for finishing aluminum parts besides anodizing?
Phil
Old Apr 29, 2008 | 05:55 PM
MikeGyver's Avatar
Sometimes I'll sandblast, wash and spray aluminum parts with clear enamel. It gives a factory-sand cast appearance. You could do other finishes, like Scotchbrite, etc. The enamel (from a spray can) seems to hold up on sand blasted parts, I've never tried it with other finishes.
Old Apr 29, 2008 | 06:03 PM
7 Second Club
Main thing I am worried about is IF I paint/clearcoat them is it going to stick. I'd love to paint them and forget about it.
Old Apr 29, 2008 | 06:25 PM
CTSmechanic's Avatar
Looks like you answered your own question.. I like scotchbrite... touch up in a box...
Old Apr 29, 2008 | 07:46 PM
7 Second Club
Anything special to painting aluminum? Or just rough up and shoot.
Old Apr 29, 2008 | 07:56 PM
Shawn @ VA Speed's Avatar
paint sticks to alum just as good as anything,just hit it with some scotchbrite and paint it
Old Apr 29, 2008 | 08:00 PM
TLewis4095's Avatar
Powder coat....durable & looks awesome.
Old Apr 29, 2008 | 08:26 PM
good idea-x2 on the powdercoat
Old Apr 29, 2008 | 08:27 PM
v8pwr's Avatar
Paint does not stick to aluminum very well without proper surface prep . A clear powder coat is durable and can handle the higher temps . I've used Glisten PC with great success following appropiate surface prep . Glisten is made by the same manufacturer as POR 15 and very durable . I've never exposed it to temps above 150 F but it handles it and looks great . Although more expensive , hard anodizing is the **** when it comes to aluminum and can handle nearly as much as the parent metal . Of course there's always standard anodizing .
Old Apr 29, 2008 | 09:19 PM
Depending on how good your welds look I dont think anything looks better than raw alum with perfect welds....
Old Apr 29, 2008 | 09:56 PM
1BadAction's Avatar
Engine turning... use a rotary sander with some 180 or 220 grit, pick it up and over lap it. it should stay nice for a good while, but if you clear powdercoat it, it will last damn near forever. you can also use some bulldog adhesion promoter and shoot clear directly over it for a slick finish.
Old Apr 29, 2008 | 10:49 PM
01ssreda4's Avatar
we paint cast pieces at work. we do a low pressure glass bead in a cabinet then paint, or do a cleaner called alkanox(or something) like a detergent then paint. never had a problem with it sticking....buts its cast aluminum.
By Brett Foote | 2026-06-04 05:00:17
