New toys from Sears - Tool Chests
Heavy isn't it. I took mine down a flight of stairs, by myself! Just about didn't get it down there. Nice compressor. Hey since it's Craftsman will they replace it free when it breaks?
I think that lifetime warranty only applies to hand tools, not power tools. I think there is a 1 year warranty on power/air/etc.. tools.
Drill bits, bolt extractors, and tap and die sets are not warranted either. I can see drill bits. But I think a tap and die set should be warranted...you really don't wear those out.
I bought a larger Craftsman Ball Bearing setup a couple years ago when it came out. My problem now is that besides a) Ive run out of room, b) the drawers are difficult to get to stay closed. I open one and because the set isnt %100.0000 level, several other drawers start drifting open. I shut those and others start sliding open. Its like a bad "whack a mole". THe newer Craftsman ball-bearing stuff has a latching handle, and that looks like it would be highly superior. So I need something a) bigger and b) good at staying closed.
Good looking setup! I run my air tools at 120-140 psi though, so I like the dual stage setups. Someday I'll pickup a much larger one.
tools RULE!!!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
chris
tools RULE!!!
chris
btw.... The big BIG deal to me right now is...
LIGHTING. I htink everyone should start sharing their lighting setups.
I use dual metal-halide 10k 300w lamps so that the light is good light (not some anemic sick yellow) and the duals help the shadows. THeres a set of backup 4 4' garden light flourescents.
I call the MH's "My two suns". I love them.
chris
chris
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#34
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
and too little lube are right easy to snap off.
Especially if you don't pull it back out often
enough.
(Cue Beavis & Butthead)
Plenty of broken ones in my tap & die box. The
only reason I kee 'em is, you can grind the broken
end flat and get a usable "bottoming tap" for
chasing blind bolt holes with.
#36
tools RULE!!!
chris
tools RULE!!!
chris
I got one of the 'grip latch' professional units. its a top chest alone. the idea onit is nice, but on mine you have to be right in the middle to get it to pull open, the deaper heavy drawers open a little better, but oh well.
Its not like it takes much time to move over to the center....
#39
They look identical to my chests and mine are Friction.
#40
They look identical to my Craftsman chests and mine are Friction.
Anyway, it's a pretty sweet deal, but for the record... they don't fit inside an F-body
