What bit for die grinder for TB porting?
I've also purchased cutting bits from Summit, they clear away material really quickly. They work well on aluminum, but steel can be a bit dangerous with cuttings (aka splinters).
By abrasive roll you mean like the kit from jegs/summit or can i buy just that somewhere??
I think it's under $40... There are tons of things you will use it for, and it basically lasts for years. It's a good investment. I'm still on my first kit, and have used it a lot. For a finish I'll be making my own sanding rolls. For finishing them off, anything in the intake up to the fuel injectors should be as close to a mirror finish as possible.
