Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Harbor Freight Trans Jack
Old Sep 18, 2008 | 09:32 PM
SScam68's Avatar
Yeah, it's a kwiklift
Old Sep 19, 2008 | 12:24 PM
ShevrolayZ28's Avatar
The scissor jack is a decent value. It's kind of flimsy but if you're not a pro trani swapper it'll do the trick.
Mine buckled a lil bit under my 4L80 but still works OK.
Old Sep 21, 2008 | 03:09 PM
rebuilt's Avatar
I have one also. Did a clutch swap in my T/A, a coupla mustangs and removed a Explorers tranny with it also. For the money it works good.
Old Sep 21, 2008 | 05:43 PM
SScam68's Avatar
I would agree. Next best thing to a real lift.
I've worked on several cars with it and it makes life easy.
Old Sep 24, 2008 | 07:47 PM
01ssreda4's Avatar
the scissor type did ok with my 60. i noticed that i couldnt ratchet the strap tight bc of its enormous size along with the fact that it was too close to the floorboard. i also noticed the metal pad for the tranny to sit on is very slick without the tranny pulled down to it. luckily i had hilton there to catch it before it hit the concrete. his hand hurt for the rest of the weekend im sure.
Old Apr 14, 2010 | 05:33 PM
FxsX24's Avatar
i have had this jack for over a year now, little scary at the top, but it is ok
has anyone come up with a better system for tilting the trans back? the wing nuts are junk, and you cannot really adjust it once you lift it.
also another issue i have is, once i get a trans into place, the ratchet seems to always be stuck in the tunnel
Old Apr 15, 2010 | 03:10 AM
Jeff Smith's Avatar
HF is very much JUnK.Made in somewhere (not in U.S.A)..
Old Apr 15, 2010 | 03:16 AM
Jeff Smith's Avatar
I copied from my past file>>
It was 1 years ago. I still use and still good condition/shape>>
I made order Arcan XL35 (#144236) 3-1/2 ton and can liftup ~20" & 1 yr warranty thru NorthernTool.com. It costs me 149.99 plus s/h $59 to my "business garage"= ~ $227.
I had been researched on floor jack thru few forums/consumer reports/others. I hope so, I made choose the best jack lif-up>> Arcan XL35.
I copied from Northern Tool.com:::::
http://www.northerntool.com/webapp/w...5429_200345429
8 out of 8 would recommend to buy......
Old Apr 15, 2010 | 10:17 AM
01ssreda4's Avatar
I cut the lower mount off on the ratchet side and made a small extension down, then welded the ratchet bracket to that. That way it clears the tunnel.
Old Apr 15, 2010 | 12:18 PM
Jimbo1367's Avatar
Originally Posted by SScam68
I bought the hydraulic version
Love it
I have the same. Used it once thus far on a th400. wORKS GOOD. so FAR
Old Apr 15, 2010 | 12:31 PM
collier341's Avatar
^^ Used that one to pull my trans also... Worked great for me.. Harbor freight is lagit in my book.
Old Apr 16, 2010 | 10:42 PM
  #32
97LT1's Avatar
Are you craftsman guys serious? Half of craftsman is the same china junk now anyway. I have had hit or mis with HF and craftsman both. I have the trans jack from HF and it works ok.
Old Apr 18, 2010 | 03:39 AM
  #33
35th SS's Avatar
looking at a trans. jack right now from napa and its on sale for 420 bux. 1000 lb. cap.need it to go on my 2post lift so I can start doin tranny work.
Old Apr 18, 2010 | 03:28 PM
  #34
SScam68's Avatar
I'm all for spending money on GOOD tools. But the $$$$ starts to add up real quick and prevents me from buying go fast goodies.
I would spend the coin on a name brand jack if I was a mechanic, but I'm not. Just a hobbyist. Harbor freight stuff works for what I need, and the frequency that I use it.
I have used it several times and have loaned it to friends. Still no problems what so ever.
Old Apr 18, 2010 | 04:31 PM
  #35
salemetro's Avatar
Exactly right! Same with Snap-On....air tools are made in China (says right on the box lol). Granted, HF stuff is often one-time-use stuff, but all of it has a warranty. Also, for those that are all keen on Craftsman sockets, etc....just buy HF impact sockets, and you'll still be money ahead. Yeah, it sucks to be buying so much foreign stuff, but when the USA equivalent is still made "over there"..but for 2x the price, why bother? Case in point...I bought a Ramsond Plasma/Tig/Arc machine for $700.00 last year. Guess what? It cuts better than my friends Hypertherm plasma AND has a tig function! Would I use it in a "production" environment...hell no! But, for the price and abilities, it suits me fine. Too bad that the "American-made" brands don't make comparably-priced and equipped units for the do-it-yourself folks. Not everyone needs commercial-grade stuff. They are missing out on a huge market.
Old Apr 19, 2010 | 10:35 AM
  #36
AChotrod's Avatar
happy with my HF trans jack. Hate the fact its made in China but couldnt justify spending a ton on something Ill hardly use
Old Apr 19, 2010 | 10:43 PM
  #37
35th SS's Avatar
might have to look that up on thier site.
Old Apr 28, 2010 | 03:29 AM
  #38
davidws6's Avatar
Default Trans Jack
Some of the stuff I've bought from HF has been ok, yet other stuff, not. But for the weekend warrior, prolly ok.
I bought a used trans jack, naturally made in China. The Jack was leaking down. I contacted many hydraulic repair shops and they said the Chinese jacks are usually throw aways. Did a search online and found http://www.usjack.com/
Got a replacement jack from usjack for $ 20 more then what Grainger wanted for a chinese made jack ! I had to make a mount for it but works great for dropping trannys.
Makes me sick also when I go into Sears and see many things made in China. I try to buy USA made, but anymore it's almost impossible for certain things.
Old May 12, 2010 | 10:38 AM
  #39
garygnu's Avatar
made a trans cradle to work with my floor jack.
Old May 12, 2010 | 08:17 PM
  #40
quews6lime's Avatar
wow!!!!!!!!!
