uploading pic problem
The error message can mean different things and there is a few different areas of the site where you can upload content, so need to know where you're trying to upload your content. Using the Attachment manager for posts? In the Photo Gallery/Album manager?
As I'm not sure where you're attempting to upload your content to, I can only advise that the Attachment Manager makes notes as to the file size/type allowed, and the Gallery notes the max file size per image as well.
Currently, max file size, per file, for a picture (generally jpg) is 488.3 KB which is less than half a 1MB. With today's cameras and their megapixels, you'd likely need to use photo editing software to crop and/or reduce the images after taken from a camera in order to upload them as attachments.
If you wish to attach an image in a post by uploading to the LS1Tech vBulletin database*:
- When you create a thread or are posting a reply to an existing thread, simply click on the Manage Attachments button that is located under the text box where you normally type your message. See Figure 1 below:
- Once you've clicked on the Manage Attachments button, you will see a new Manage Attachments window. Click on the Browse button to locate the file on your computer. When you have found it, click on the OK.
- Click on the Upload button
- Once you've uploaded your image, you should see the file listed under the "Current Attachments" heading. You can then close that 2nd browser window. The file names should appear under the "Attach Files" section. When you're finished with your message, click on the "Submit Reply" button. The image will be uploaded to the LS1Tech vBulletin database, along with your regular message. See figure below:
If you already have your image hosted online:
- Copy the URL of your image that you wish to post. Simply locate your image online, and then right-click on the image and select the "Properties" option, if using Internet Explorer. The URL is listed under the "Address (URL)" section. Highlight the address shown, then right-click and select "copy". The URL will now be copied to your Window's clipboard for later use.
- When you create a thread or are posting a reply to an existing thread, click on the image icon (see Figure below), which is located just above where you normally type your reply message. When the prompt appears, delete the existing text http:// in the field, then right-click and and select the "Paste" option. The URL to your image should now be in that field.
Note: Make sure to only have 1 http:// in your URL.
- Click on the "OK" button.
You'll see the image's URL is then placed inside the [IMG][/IMG]tags.
Are you seeing any errors? Are you still seeing the security token error? If so, the files are too large and you need to reduce them to comply with the specs listed in the attachment manager, which are:
bmp 341.8 KB
doc 100.0 KB
efi 634.8 KB
gif 488.3 KB
hpl 683.6 KB
hpt 1.24 MB
jpe 488.3 KB
jpeg 488.3 KB
jpg 488.3 KB
pdf 341.8 KB
png 488.3 KB
psd 341.8 KB
tun 1.24 MB
txt 100.0 KB
zip 100.0 KB
If the attachments were successfully loaded, they should appear in the manager under the Current Attachments.
I checked the database and it does show that you have not uploaded anything. So either you're getting some sort of error message, or there is something likely wrong with your browser. What browser are you using?
BTW, I attached an image to this message without issue.
i uploaded pics on the PY site and it worked fine there
http://www.gimp.org
(Has Windows version)
http://www.irfanview.com
The latter is a very lightweight software program that can do quite a bit of basic things (resizing, cropping, etc.) while the former is much more complex and has more features.
I can upload pictures using the instructions below, my question is how do you get them to appear full size in the thread?
Usually I go back and edit it, open up the pic in a new window, copy the URL and add the picture. Is there an easier way?
However, with a few extra steps, you can display a normal sized attachment inside a post in addition to the standard thumbnail.
When you upload an image(s), and you then see the filenames of the uploaded image(s) as seen in this step:
You can right-click on those filenames to get the URL/Address. Copy the URL/Address and place it inside a set of [img][/img] tag. That way, the image will be displayed in the post a normal size, as well as a thumbnail attachment.
I've demonstrated, in this post, the above by uploading the LS1Tech banner as an attachment, and then also copy/paste the URL/Address of that uploaded attachment and placed it inside a set of [img][/img] tag.
[IMG]http://[IMG]http://i406.photobucket.com/albums/pp147/71ANTICARB/Fuel%20tank/IMAG0120.jpg[/IMG][/IMG]
There are two issues with your example. You had two sets of [img][/img] tags. You only need one set of [img][/img] tags per image. [img] goes at the start of the image link and [/img] goes at the end of the image link.
The second issue was you had two sets of http:// prefixes when you only suppose to have one.
So, the following would be the correction:
to display as:
[/IMG]
