03 cobra built motor whipple 3.4 built 4r70w solid swap
Black 03 Cobra 78,000 miles $28,000 or fbody/foxbody + cash or corvette
Motor built 40k miles ago
New block from ford
Probe pistons 8.3:1
New Stock rods
Stock Crank
ARP fasteners
Cleaned up heads
Comp Stage 3 cams
Whipple 3.4l with 3.5 and 4.0 pulley
Built 4r70w Jerry Labowski Build
Overdrive and lockup
3500 PI converter
B and M wratchet shifter
Built 8.8
Auburn unit with 3.90
31 spline axles
Welded torque tubes
Tubular lower control arms and adjustable upper contol arms
Strange 10 adjustable rear shocks
Lakewood 90/10 front shocks
Steeda Anti Roll bar is included
17-9.5/10.5 deep dish replica cobra wheels with 555r drag radials
Fore Precision fuel hat with ford GT pumps, -8 fuel line, fore precision fuel rails with 60lbs injectors
JLT Cold air, Kooks long tube heades with x pipe and magnaflow mufflers, Triple pod pillar with boost, aerforce interceptor, and oil, Double din tv
New block from ford
Probe pistons 8.3:1
New Stock rods
Stock Crank
ARP fasteners
Cleaned up heads
Comp Stage 3 cams
3500 PI converter
Built 8.8
31 spline axles
Welded torque tubes
