83 Rx7 Project - Caged, Full suspension, LQ9 w/ T5 trans
83 Rx7 Race Car
Things the car comes with:
- Shell, all glass minus left side quarter glass (new front windshield)
- 15x8 -6 offset rear steelies with brand new tires
- Custom Toyota Rear end (super beefy!) Weld locked rear diff. Redline synthetic ran in it
- Custom 240sx Coilover rear suspension, adjustable ride height, and dampening
- Respeed Front coilover setup, 350lb springs, race perch setup, and coilover sleeves
- Brand new brake master
- Custom aluminum dash with Boost pressure, oil pressure, and water temp gauges.
- 7 pt. cage (made for maximum cabin space)
- Rear mini tubed (can fit 17x10's)
The bad: has two spots of rust (both easy to remove.) one is on the driver side rocker, the other is along the welded seam where the drives feet rests.
LQ9 Motor has 104,000 miles on it, looks clean. Comes with:
New Corvette exhaust manifolds (block huggers)
Truck exhaust manifolds
04 GTO LS1 low rise intake manifold
Truck intake manifold
04 LS1 returnless fuel rail W/ injectors
Truck injector setup W/ injectors
T5 Clutch and pressure plate, flywheel
Shifter w/ ****
T5 driveshaft from a 85 camaro
Truck Flexplate
Truck Coil packs
04 GTO wiring harness w/ trans harness (fully labeled)
Possibly some other random stuff.
Pics
![](http://i35.photobucket.com/albums/d190/driftking777/DSC01176.jpg)
![](http://i35.photobucket.com/albums/d190/driftking777/RX7/DSC01078.jpg)
![](http://i35.photobucket.com/albums/d190/driftking777/RX7/RXsuspension.jpg)
![](http://i35.photobucket.com/albums/d190/driftking777/RX7/RX7Neardone4.jpg)
![](http://i35.photobucket.com/albums/d190/driftking777/Ls1%20swap/DSC01594.jpg)
Some of the pictures are older, so if your seriously interested i will take more pictures.
Asking price is $4000 obo
It needs some work still, the car has been running with a different motor setup, feels nimble and handles well. Setup for several styles of racing.
Shifter w/ ****
Truck Flexplate
Truck Coil packs
Pics
1983, 83, accessories, block, cadillac, corvette, cost, drivetrain, glass, lq9, removal, rx7, set, setup, suspension, transmission, truck
