98 TURBO trans am, 6 speed,loaded and bombed..cheap
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $6800
Mileage: 80000
Private or Dealer Listing: Private Listing
Location (State): PA
Color: Gray
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Car has a broken piston and cracked rod on #1..i have not taken the car completely apart but from the looks of it the whole block is junk, I do have a friend with a built forged 390 6.0 irion long block with heads i can direct the person who buys this car too for $2200.. Every thing else on the car is in good shape and has low miles..stock pistions did not appreciate 12psi of boost very long and i dont want to mess with it anymore...
I also have a pile of recipets for most of the parts bought to build the car..
I have the turbo kit listed seperate but it is not off the car yet..trying to either part car or sell as whole..which ever happens first
Call for more info 410-218-1620
-Presicion turbo kits hot side stainlesss exhaust
-Presicion Turbo polished turbo with the race cover,360 race bearing and intake horn and T4 flange 3" V band exhasut (capable of 700hp)
-large sheet metal front mount intercooler
-jdm BOV and wastegate (10lb spring)
-COMP custom grind turbo cam with 623 lift single pattern cam
-LS2 lifters
-PAC dual coil hi rev springs
-TSP 7.400 hardend push rods
-Ported 318 truck heads,PAC springs,Ti retainers fresh valve job with new SS valves
-roller master adjustable timing chain set
-TSP ported LS6 oil pump
-LS6 intake
-ported throttle body
-LS2 plug wires
-NGK TR6 plugs
-ARP rod bolts
-ARP cam bolts
-ARP head bolts
-MLS head gaskets
-LS2 header gaskets
-LT1 radiator
-twinn electric fans(one pusher one puller)
-hyper tech 160 therm.
-Siemens matched 60lb fuel injectors
-Converted to speed density with GM 2 bar map
-twinn walboro 255lph intank pumps (one ran off a 4psi hobbs switch)
-SLP loud mouth cat back
-ZR-1 wheels painted same color as car
-bilstien shocks and struts
-sportline springs in front
-all WS6 suspension
-cross drilled and slotted front rotors with hawk pads
-Pro 5.0 shifter base with a tri-ax billet handle
-no converters,egr,evap or air pump
-auto meter oil pressure
-AEM wideband o2
-Boost gauge
-inspected till 7/11
-spohn chasis mount chromoly tourqe arm
--im sure theres more im forgetting
so does it just need a shortblock are the heads messed up too? shoot me a PM if you dont mind and your location.
EDIT: just saw the guy above me bumped a 6+ month old thread, PM me if its still for sale though, sorry if it isnt.
