Year: 2001
Make: Pontiac
Model: Trans Am
Price: $15000
Mileage: 98000
Private or Dealer Listing: Private Listing
Location (State): GA
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
2001 Pontiac Trans Am WS6 pewter and black leather interior 500+ hp at the crank 413hp at the rear wheels. 6 speed manual, T-tops with shades. It has a MS3 cam (BIG CAM SOUNDS GREAT), patriot dual springs good up to 650 lift, ls2 timing chain, chromoly pushrods and titanium retainers, new valve seals, Pacesetter ceramic coated long tube headers with off road y-pipe and electric cutout Flowmaster exhaust, polyurethane motor mounts, Shaner s3 ported throttle body, Slp air lid, smooth bellow , Fidanza aluminum flywheel, Luk pro gold clutch, new slave cylinder with remote bleeder valve, new clutch master cylinder, new water pump, new transmission output shaft, Asp under-drive pulley, MOSER 9" rear end with 3.70 gears, Pro 5.0 shifter, UMI sub frame connectors, adjustable shift light, ZR1 wheels 17.9.5 with Nitto 285/40/17 in front 17x11 in back with 315/70/17 Nitto drag radials, 10 disc cd changer in trunk with steering wheel controls, t-tops, tinted windows,front shock tower brace, polyurethane bushings on both sway bars, 30 anniversary racing stripes. AND MUCH MORE THIS CAR IS GARAGE KEPT, BABIED, AND VERY CLEAN, MUST SEE AND HEAR!!!!!!!! CAR HAS NEVER BEEN TO THE TRACK!!
Marc 770 789-1317 $15000 LOCATED IN ACWORTH GA
