99 mustang GT. built patriot heads and procharger included
Year: 1999
Make: Ford
Model: Mustang
Price: $10000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
also has all the int out of the 03 swapped into it, and alum window/lock switches,rear defrost button, headlight switch, tilt lever. has a nice sony radio, with brand new clarion 6x8s in the front doors and recent ma audio 5.7 in the rear deck.
the rear end was just re built with all new bearing and seals, also put a saleen max grip diff with 3.73 gears, and superior 31 spline axels
the car has a set of drag springs with 3 way adj drag shocks in the rear and the stock 03 fronts with drag springs also just did the lower ball joints also just put new cermic pads and new rotors on the front and also have new rear cermics not installed(old one still have about 8-10k on them)
has a off road x-pipe and magnaflow exh and a k&n filter, also have a diablo tuner.
car also has cobra front bumper and and 17x9 cobra wheels, mach 1 lip, all the 35th anv interior parts, and the truck filler piece from the 35th, has cobra badges(have the stock 35th one also), fresh tint
also have a set of built patriot heads with blower cams. they have ferra valves, titanium dual spring and retainers. cnc ported. i for get the specs on the cam but i know there were blower cams. i just had them at the machine shop getting cleaned and inspected also had him deck the head so there ready for install.
also have a procharger set up that was off a 97-03 f-150 4.6 it will need a bracket, the blower will need clocked so it points down, you will also need some intercooler pipes made. it has a nice 2 row intercooler, the boost a pump, a fuel PSI gauge, procharger blow off valve. will just need a few mods to fit the car.
asking 10,500.00 for everything obo. will consider trades but all trades must have a/c, im fat and florida is hot lol. really looking for something else fast but will consider something else cool lol
only thing the car needs is a heater core. its bypassed now.
now on to the pics
these are how it sets right now.
these are alil older
during the swap
i got a whole box of parts not in pic
and the heads. you can see the cams have a nice lobe, and have a purty good duration on them
cnc ported intake
fresh mounting surfaces
