FS/FT 97 Camaro low 9 sec LS nitrous drag car
Year: 1997
Make: Chevrolet
Model: Camaro
Price: $20000
Mileage: 10
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Engine:
LS1 fresh built, Trickflow 225cc heads CNC ported by TEA, solid roller(all Comp parts) with custom grind cam, Jesel shaft mount rockers, GRP aluminum rods, CP pistons, VicJr intake with Accufab 4150 style throttle body, CPR fuel rails, 42# injectors, billet girdle, ported oil pump, Billet valve covers with remote coil mount, vacuum pump, Cometic head gaskets, Kooks stainless headers 1 7/8 stepped to 2 inch with 3.5 inch collectors, all bolts in motor are ARP, Mezeire electric water pump. Motor is making a little over 500 n/a.
Driveline:
Built TH350 with transbrake, 4000 PI nitrous converter, carbon fiber driveshaft, 12 bolt Moser rear with 411 gears and spool, 33 spline axels
Suspension:
QA1 coilovers in front, Spohn tubular k member, Spohn solid motor mounts, Spohn subframe connectors, Spohn tq arm with driveshaft loop, BMR double adjustable tubular lower control arms, Spohn tubular panhard bar, BMR drag bar, tubular trans mount
Electronics:
BS3 standalone engine management with laptop, has aftermarket gauges for nitrous, oil pressure, water temp, volts, rpm window switch, tach
Interior:
full interior with stock dash, door panels, carpet, console, etc. all in really great shape, Kirkey race seat with 5 point harness, 6 point roll cage, Hurst quarter stick auto shifter
Exterior, Wheels, Tires:
Factory paint in really good shap, cowl hood, Weld RT-S wheels, front 15x4, rear 15x10, Hoosier drag radials, Moroso skinnys
Nitrous:
Brand new never sprayed Nitrous Pro Flow plate kit by Wilson with burst panels, fuel standalone system
Im sure there is a lot I left out. If you have any question please ask. This car is done right and has a lot of high end parts on it. Im asking $20000 obo or trade for a Vette(C5 and up), turbo cars, supercharged cars. I have had this project a while and I am maybe looking to move on. It does not have to go so please do not try to lowball or waste my time.
Bump up, where are the trade offer guys? Price is obo. What I have listed is a starting point with price. The car has ran mid 6's @ 105 on motor. On the gas it will go high 5's.
Thread update.........I will still sell or trade this. Car has gone through some changes since I started the thread. The car sits lower in the rear than in the pic above, light weight carpet installed, all new switches installed that control fan, nitrous, heater, etc. Also, the car has been in the 5's in the 1/8 and deep 9's in the 1/4 @ 140+++. Will sell for 20,000 or trade for turbo car, Vette, or some old school hot rods or muscle car. Here is a vid of it running. My car is about 1 minute in.
https://www.youtube.com/watch?v=P_9Z...e_gdata_player
It's fine in the street. Stock compression and it doesn't over heat at all. No bucking since its auto and the converter eats it up. It doesn't drive or ride like a Cadillac though since it has skinnys, no sway bar in front and drag bar in there rear. I guess it depends on the Pontiac if I will like it or not. Never hurts to try.
