2002 Camaro Z28 416 CI Nitrous Motor (Sold)
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $18000
Mileage: 34000
Private or Dealer Listing: Private Listing
Location (State): GA
Color: Silver
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Up for sale is my 2002 Camaro (Roller). 34K Original Miles.
Car has title and can be registered in the right state.
Engine:
Fully forged and balanced 416 LS Iron Block
Eagle Crank and Rods w/ ARP 2000 rod bolts
ARP Main and Head Studs
Wiseco Pistons and rings
AFR 225 Heads with EHT .675 Springs
Comp Cams Pushrods
T&D Shaft Mounted Rockers
Comp Cam Solid Roller Nitrous Cam spec'd by Martin at Tick
Comp Cam Link Bar Solid Roller Lifters
Rollmaster Double Roller Timing Chain
SLP Underdrive Crank Pulley (Zero Balanced)
TCI Flexplate (Zero Balanced)
Super Victor EFI (Ported)
Holley 50# Injectors
Accufab 4500 Dominator Throttle Body
Meziere Electric Water Pump
Nitrous Outlet Stinger Plate (Jets from 100hp-400hp)
NX Nitrous and Fuel Solenoids with -6an lines
Poly Motor Mounts
Interior:
Kirkey Seats (Driver and Passenger)
5-point harness (Both sides) with Camlocks
Grant Steering wheel
Hurst Shifter
Wolfe Racecraft Chromoly 6-Point cage
Autometer Cobalt series Tach, Trans temp and Nitrous Pressure Gauges
AEM Wideband
Carpet, stereo and speakers still in car. Stereo works.
Remote Keyless Entry
Power windows and locks still operable
BMR Trunk Mounted Battery Relocation
HVAC system removed (No heat or AC)
Exterior:
VFN Sunoco Bolt on Hood
SS Rear Spoiler
Weld Drag Lite 15x10 (Rear) 15x3.5 Front
Mickey Thompson Front Runners and 28x10.5s rears with tubes
Suspension:
QA1 12 way adjustable coil overs on Front (300# Springs)
QA1 12-way adjustable shocks on Rear
Spohn Adjustable Drag Bar
Spohn Adjustable Torque arm with Driveshaft Loop
Spohn Adjustable LCAs
BMR Adjustable Panhard Bar
Diamond Subframe Connectors
Drivetrain:
Currie 9" Rearend. 3.89 gears and Spool
New Hughes TH400 RMVB with Transbrake
New PTC 4000 Nitrous Stall
BMR TH400 Crossmember
3.5" Aluminum Driveshaft with 1350 U-Joints
Aeromotive 340lph fuel pump with hotwire kit
Included:
1 Gallon Custom Nitrous Cell with 255lph high pressure pump
Kook 2" Headers, 3.5" Collectors
Two Sets of slip on Mufflers
Two Nitrous Bottles
Progressive Nitrous Controller
Lingenfelter LCN-002 Two Step Launch and Timing Controller
HP Tuners with credits for the car.
Price: $18,000
ttt
i just sold my 99 ss silver 30k miles. same set up. except built 4l60e ,,,with a head /cam/nitrous set up. for 10k. i felt it was worth 13k .. just lettin u know,,,,,that car with a stout ls1 is around 10 to 13k. i know it sucks. but thats the f body reality as of late
What does it run in the 1/4?
hw about yours complete for a beautiful 66 nova 2 door mines less motor very low miles nice interior has glide with it for yours complete this with a lsx motor is a 30,000 car look them up,i do have a 5.3 long block and ls1 intake 38lb injectors ,if I was you id freshen the 5.3 up its has sat for a few years, up to you you know your stuff,im going to lights out next week if you want to meet and talk in Valdosta,id like to see your car can you bring it there
