1968 firebird ls7 engine
Year: 1968
Make: Pontiac
Model: Firebird
Price: $25000
Mileage: 999999
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Gray
Transmission: Manual
Drivetrain: Front Wheel Drive
1968 firebird
12 bolt rear end
3500 miles ls7 engine. Made 509 not corrected at the wheels. Car drives fine, but needs fine tuning with the tune.
New LS7 block and crank
Lunati ProMod billet rods
Wiseco forged 11.25:1 pistons and rings
ARP main studs, can't remember what bearings
QM600 cam. 243/256 .650" lift
Ported stock Ls7 oil pump, cloyes tchain
WCCH LS7 heads stage 1- exhaust port cleaned up, intake stock, multi angle valve job, dual springs with titanium retainers, titanium intake valves, s/s exhuast valves, new guides, stock ls7 rocker arms rebuilt with Comp Cams trunion bearing kit.
ARP head studs, LS7 head gaskets
Ported LS7 intake and holley 92mm tb
Speedtech oil pan, engine mounts, trans crossmember
Griffin dual pass radiator with ls1 camaro fans controlled by ecu
500 mile magnum transmission with mantic clutch
Peterson oil tank/breather
-12 fragola oil lines/fittings
-8 fragola pfte fuel lines
Aeromotive tank with pump
Hotchkis subframe connectors
Speedtech upper/lower control arms
Wilwood dynamite 13" 6 piston fronts
Us mags bandit wheels 17x8 front 17x9 rear nt05r drag radials on the rear
Interior all original, needs up dating
Speed hut gauges.. Tach fuel, oil press, water temp
New floor panels
Painless wiring harness
Body
Doors, rockers, roof solid.
Passenger 1/4 good but needs patch panel behind wheel
Driver 1/4 need wheel arch and panel behind wheel
Back panel needs patch
Paint 6/10
$25000 obo. No trades at all.
904-403-0287
[URL=http://s252.photobucket.com/user/68birdls1/media/C529AA76-6C1A-417E-99EB-B56AB0EE368A_zpsvch17ywi.jpg.html][/URL
[URL=http://s252.photobucket.com/user/68birdls1/media/A31AD76C-4B3A-4376-8B9E-801F6FF544D7_zpsia8wqsjg.jpg.html][/URL
[URL=http://s252.photobucket.com/user/68birdls1/media/D7C93971-566C-4849-9A5C-641D194AC2D3_zpsgnjjauiv.jpg.html][/URL
