Toyota Supra single turbo LS1 powered
1989 toyota supra targa project ls1 single turbo 99% done!!!
MODS:
FULL INTERCOOLER KIT WITH CUSTOM IC PIPES
GREDDY TYPE S BLOWOFF VALVE
AFTER MARKET 14IN 2600 CFM ELECTRIC FAN
KOYO POLISH PERFORMANCE RADIATOR
MKIV APEXI GT SPEC 3 ¾ EXHAUST
WALBRO 255 PUMP
GREDDY PROFEC B SPEC2(BLACK)
GREDDY ELECTRONIC BOOST GAUGE WITH MEMORY
GREDDY EGT GAUGE
HKS SAFR FUEL CONTROLLER
BLITZ TURBO TIMER
RED TOP OPTIMA BATTERY
ALPINE HEAD UNIT AND SPEAKERS
EIBACH SPRINGS W/ TOKICO BLUES
CROSS DRILLED FRONT ROTORS
AEROMOTIVE FUEL PRESSURE REGULATOR STEEL BRAIDED LINES AND GAUGE
STEEL BRAIDED FUEL DAMPER LINE
STEEL BRAIDED PS LINES
BOMEX REPLICA FRONT LIP(CURRENTLY NOT ON CAR BUT CAN BE INCLUDED)
1998 LS1 WITH ~60 K MILES
1998 4L60 E WITH ~60 K MILES
COMPLETE CUSTOM TURBO KIT BUILT BY AUTO ADDICTIONS IN ROCHESTER.
TURBO IS A CUSTOM T70 WAS PUT TOGETHER BY TURBO CONCEPTS
SWAPPED LS1-WITH CUSTOM MOTOR MOUNTS
CUSTOM DRIVE SHAFT LS1 TO SUPRA REAR END
CUSTOM STAINLESS TURBO MANIFOLDS FOR LS1
HEAT SHIELDS FOR MANIFOLDS
3” STAINLESS V BAND CLAMPS
2.5” FLEX CROSSOVER PIPE
HEAT WRAP FOR HEADERS AND CROSSOVER PIPE
BATTERY BOX AND WIRING FOR BATTERY RELOCATION
CUSTOM DOWNPIPE TO EXISTING 3/3/4 APEXI CATBACK
2 WIRE COOLANT SENSOR
CUSTOM TRANS CROSSMEMBER
CUSTOM MSD PLUG WIRE KIT WITH NGK PLUGS
CUSTOM INTERCOOLER PIPING AND FRONT MOUNT AIR TO AIR INTERCOOLER
STAINLESS VACUUM BLOCK
CHEVY OBD 2 PORT
BRAND NEW PAINLESS WIRING HARNESS (9
2 99 ECU’S INCLUDED
POLISHED ALUMINUM WHEELS 5 SPOKE DEEP DISH WITH NEWER TIRES, 17X11 REAR, 17X9 FRONTS
CUSTOM FABRICATED DASHBOARD WITH FULL AUTOMETER GAUGES.
All the car needs is a transcooler, radiator, and an ecu to be hooked up! Open to offers asking 11,500 have all reciepts for labor done along with anything I may have missed. To come take a look at the car call Joe at 586-738-8885
MODS:
WALBRO 255 PUMP
GREDDY EGT GAUGE
BLITZ TURBO TIMER
CHEVY OBD 2 PORT
2 99 ECU’S INCLUDED
Car is located in Macomb Michigan, The Painless harness and the motor are 98, I talked to a local ls1 shop and they said to repin the harness to a 99 so I have a 99 ecu...But I moved to california and ran out of money to finish the car with a local shop, so I am selling it the way it is, all it needs is the ecu to be hooked up, radiator put in and a trans cooler. its 99% done, if I were ther I would finish it, I have a frien selling it for me and he has the title and everything ready to go. I fyou have any questions feel free to call 586-604-2492, Matt
