1990 IROC-Z (11.66@117.20) w/33,110 miles Located in Virginia
Old 09-07-2007, 04:33 PM
Apathetic's Avatar
Default 1990 IROC-Z (11.66@117.20) w/33,110 miles Located in Virginia
NEW PRICE $8,250 as of 2/24/2008
Pictures and old price are at bottom of write up.
The car has 33,110 miles. I am the third owner of this car. I purchased it May 5, 2004 from a fellow member of a car enthusiast site who actually built the car to what it is today. The only things I changed about the car from the way it was built is I swapped in the non-AC box, re-installed the fog lights and put in a new heater core. The car has run a best of 11.66 @ 117.20 by the previous owner and I have the video he took of the run.
The car is incredible, a total blast to drive, but I am changing things in my life. Car has a “secret” custom grind cam that I promised the previous owner I would never give out unless I sold the car. If you ask what the cam specs are I will NOT tell you until you have bought the car. If you can’t live with that then you will have to move on. My word is all I have. Obviously, if you buy the car you will receive the cam specs. The cam is a Lethal EFI Performance Custom Cam by Joe Overton. The car is tuned by TRAXION, whom also built the car and I have a TREMENDOUS amount of respect for.
Want to have a 33,110 mile stock IROC? I have many, many of the parts that will bring it back to stock that comes with the car! It’s up to you how you keep the car, but with 33,110 miles, it will likely increase in value, especially being that it is a ’90 IROC-Z-hardtop-L98. Car has many, many receipts as well as the original window sticker laminated. Everything is numbers matching. Car also comes with another set of 16” IROC rims, with the rears having BFG Drag Radials. I’ve never used them; I’ve never taken the car to the track during my ownership.
I’m selling this car and my ’91 Z28 and my ’92 Liberator 201 due to life stepping in and changing things. I sincerely hate to get rid of the IROC, I know I will miss it and I know I will want it back one day.
Negatives:
-Previous owner had the car scrape driver’s side rear bumper cover. You can clearly see this in the picture.
-Very minor nearly unnoticeable indentation driver’s side door.
-The turn signal has a slight problem when initiating a left turn signal. Most of the time you have to pull it forward just slightly while clicking it to the left. This has been like this through at least two of the three ownerships.
-I was told the trip odometer works, but not perfectly. I honestly haven’t noticed, but I have put only 282 miles on the car during my entire ownership.
THE CAR IS SOLD AS IS WHERE IS. THERE IS NO WARRANTY AT ALL. The buyer is relying solely on his/her own inspection, and not on any written or verbal representations made by myself or anyone else as to the condition of the vehicle. I strongly advise you to be a good driver. No offense, but this car is not for irresponsible drivers. I am not responsible for anything that happens to you or the car. Buyer is responsible for pick up or shipping.
The item is being transferred on an "as is where is basis" with no warranties expressed or implied as to the condition of the item. Furthermore, the "buyer" agrees to hold the "seller" and his heirs free from liability if any damage occurs from the use or transportation of the item sold.
List of mods:
Engine:
• AFR 190cc Aluminum Cylinder Heads with 7/16" Studs, drilled for EGR and Temp, and Further Porting by Advanced Valve (278cfm / 230cfm @ 0.600")
• Lethal EFI Performance Custom Cam by Joe Overton
• Blueprinted Comp Cams 987 Springs
• Comp Cams Titanium 10Ί Retainers
• Viton Valve Seals
• AFR HydraRev Kit
• Trick Flow Chromoly 7.200" pushrods
• 1.6 Competition Cams Pro-Magnum Roller Rockers
• Competition Cams 'R' Lifters
• Cloyes Hex-A-Just Double Roller Timing Chain
• 30lb SVO Injectors
• TPIS AFPR
• Walbro 255ltr/hr fuel pump
• Fluidampr Harmonic Balancer
Induction:
• Random Technology Ram-Air
• Gutted Airbox with K&Ns
• BBK 58mm TB
• TPIS MiniRam II
• Custom Fuel Lines for MiniRam
Exhaust:
• Hooker Long Tube SuperComp 1-3/4" headers
• Mufflex Y-pipe
• Flowmaster Force II 3" Catback
• Dynomax UltraFlo welded muffler
Drivetrain:
• Genuine GM 3.73 Gears
• Auburn PRO Limited Slip Differential
• LPW Ultimate Aluminum Rearend Girdle
• LPW Axle Tube Brace Kit
• Denny's 3" N2O ready shaft (w/ 1350 10-bolt pinion yoke)
• Precision Industries Vigilante 3600 stall Torque Converter
• B&M SFI Approved Flexplate
• B&M Shift Kit
• B&M Auxiliary Remote Mount tranny filter
• B&M Auxiliary 24,000GVW SuperCooler
• B&M Console Megashifter
• GM Corvette Servo
• GM 0.500/0.296 TV Boost/Intermediate Boost Valve
• Derale Starfire Tranny pan
Suspension:
• Global West VaraTrac LCA Relocation Brackets
• Global West Spherical Bearing / Del-A-Lum Bushing LCAs
• Global West Spherical Bearing fully adjustable panhard rod
• Global West TS-14 Steering Box Brace
• Alston Chassis Welded Subframe connectors
• Hotchkis Strut Tower Brace
• Sandblasted and Powdercoated stock 36mm Front and 24mm Rear swaybars
• Energy Suspension polyurethane swaybar bushings and endlinks
• Energy Suspension polyurethane tranny mount
• Energy Suspension Engine Mounts
• Air Lift airbags in rear springs
Brakes:
• Earl's braided SS brake lines
• Bendix Titanium pads
Miscellaneous Modifications:
• Edelbrock Hi-Flow Water Pump
• March Power & Amp 3-Piece Aluminum underdrive pullies
• Comp Cams Billet 3-Piece timing cover
• MSD 6AL Ignition
• MSD SuperCoil
• MSD 8.5 wires
• MFY Centerbolt Wire looms
• Moroso Billet Aluminum Valve Covers
• CSI High torque MiniStarter
• Dual 2" A-Pillar gauge pod with: Intellitronix Air/Fuel Ratio gauge and Intellitronix Fuel Pressure Gauge
• Kenwood head unit with remote 10-Disc changer and Infinity Speakers
• Air Conditioner removed
• Emissions removed
Exterior:
http://i17.photobucket.com/albums/b8...ndIROCZ/Z4.jpg
http://i17.photobucket.com/albums/b8...ndIROCZ/Z5.jpg
http://i17.photobucket.com/albums/b8...ndIROCZ/Z6.jpg
http://i17.photobucket.com/albums/b8...ndIROCZ/Z7.jpg
http://i17.photobucket.com/albums/b8...ndIROCZ/Z8.jpg
http://i17.photobucket.com/albums/b8...ndIROCZ/Z9.jpg
Interior:
http://i17.photobucket.com/albums/b8...dIROCZ/Z14.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z15.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z16.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z17.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z18.jpg
Parts:
http://i17.photobucket.com/albums/b8...dIROCZ/Z21.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z22.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z23.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z25.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z26.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z28.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z29.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z30.jpg
Engine:
http://i17.photobucket.com/albums/b8...dIROCZ/Z32.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z33.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z34.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z35.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z36.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z37.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z38.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z50.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z51.jpg
http://i17.photobucket.com/albums/b8...dIROCZ/Z52.jpg
I’m looking for $9,250 obo and will entertain all offers, so please feel free to make them. Thank you for taking the time to look.
Apathetic is offline
Old 09-08-2007, 10:13 PM
Apathetic's Avatar
Vids:
Old 09-10-2007, 06:12 AM
krobinson123's Avatar
bump for a beautiful car
krobinson123 is offline
Old 09-11-2007, 02:59 PM
Apathetic's Avatar
Bump.
Old 09-12-2007, 03:19 AM
Apathetic's Avatar
Up.
Old 09-12-2007, 11:13 AM
Vicious95Z28's Avatar
I'd love to have it. Always wanted a nice ROC!
Vicious95Z28 is offline
Old 09-14-2007, 02:40 AM
Apathetic's Avatar
up again.
Old 09-16-2007, 10:00 AM
j88l98irocz's Avatar
Default Iroc-z
bump! for a beautiful IROC
j88l98irocz is offline
Old 09-17-2007, 02:01 AM
Apathetic's Avatar
Thanks for the compliments guys.
Old 09-18-2007, 04:49 PM
Apathetic's Avatar
Hey Guys and Gals,
Wife has ruled with an iron fist and has said she would also consider trades on the following type vehicles:
Suburban
Suburban type vehicles
Trucks, preferably crew cab 4x4's 2500's etc., diesel preferred, gas okay
Minivan's
All would have to be straight up trades, or trade with cash to us. No rust please.
Of course, we will still sell outright.
Old 09-30-2007, 02:44 AM
Apathetic's Avatar
btt
Old 10-01-2007, 03:21 AM
Apathetic's Avatar
up, up and away.
Old 10-01-2007, 10:59 AM
floridamuscle's Avatar
how about a 2002 vw cabrio,76k,blue,blue top,vg condition,needs @ 200.00 in paintwork plus ill give you 2000 bux,im in so.florida.must come to me to swap
mikeygold@yahoo.com
http://i32.photobucket.com/albums/d1.../2002VW009.jpg
floridamuscle is offline
Old 10-06-2007, 12:24 AM
Apathetic's Avatar
Sorry floridamuscle, for some reason I am not sure of I never received an email of your reply.
I would not be interested in the Cabrio, though, but thanks for taking the time to make the offer.
Old 10-08-2007, 01:20 AM
Apathetic's Avatar
ttt.
Old 10-08-2007, 09:08 AM
Deerhunter-Z28's Avatar
maybe I missed it but what is the price?
Deerhunter-Z28 is offline
Old 10-09-2007, 12:30 AM
Apathetic's Avatar
Hi DeerHunter_Z28. It's $9,250 obo.
Old 10-09-2007, 08:25 PM
QUICK305's Avatar
I remember reading about this car on thirdgen.org back in the day. Always wondered what happened to it...
QUICK305 is offline
Old 10-12-2007, 03:24 PM
pancherj's Avatar
Is it still for sale? Where at in Virginia?
pancherj is offline
Old 10-12-2007, 09:25 PM
Apathetic's Avatar
Hi pancherj,
It's still for sale, I'm about to list it in more places very soon. I will consider every offer.
I'm located outside of Kilmarnock, Virginia.
Quick Reply: 1990 IROC-Z (11.66@117.20) w/33,110 miles Located in Virginia
