Western Members CA, AZ, NV, UT, CO, NM, HI
Another freakin suspension issue
Old Dec 24, 2008 | 06:16 PM
LS1Adam84's Avatar
Default Another freakin suspension issue
Ok so now after I took my car up to Suck my SS shop and possibly coming up with me needing new ball joints at some point and sway bar bushings. The other day I noticed my rear has been getting more and more loose. Like I make a sharp left, left turns only. The rear wiggles, you can feel it pretty hard core and makes a clunk when it does. Good grief the engine and tranny are the best parts on this car so far hahahaha. Sooo anyone got any ideas? I searched but couldn't find anything. Sum it up the rear end is moving on sharp left turns like it is trying to walk out on me which i think is not too good. Today at lunch drove back to work and well it is getting a little bit worse. So I am not getting on it too much so i don't totally cause the demise of this car.
Ohh and I will be getting this thing back up on the lift again here in the next week or so but I figured I would ask and see what could be issues and then check those first. Even though Shant is a pretty knowledgable guy and would most likely have an answer but i would see here too. call it my inquisitive nature.
Old Dec 24, 2008 | 06:36 PM
ae13291's Avatar
check the sway bar bushings or lower control arms. mine is doing the same thing as of now. even with my upgraded LCA and PHB my rear end would move enough for my tire to rub the body, but im talking super hard turns while im on the gas and turning like 90 degrees. i think it wont hurt to check the torque arm bushing as well
Old Dec 24, 2008 | 06:41 PM
LS1Adam84's Avatar
Yeah this is what I was thinking, but man I want to be double sure, I may end up spending all my christmas money buying new bushings for this guy and new ball joints.
Old Dec 24, 2008 | 06:54 PM
ae13291's Avatar
o sorry most importantly check the pan hard bar. i dont know why i said check sway bar bushings lol
Old Dec 24, 2008 | 07:27 PM
LS1Adam84's Avatar
its ok man I translated it.
Old Dec 25, 2008 | 02:03 PM
nick123's Avatar
your endlinks on your sway bar are prol worn out. just replace everything with energy suspension polly bushings. you can pick them up at autozone they are pretty cheap like 30 bucks and you will have everything you need. i would do that first to see if that fixes the problem. if its still doin it the maybe try replacing the torque arm bushing. thats just what i would try.
Old Dec 26, 2008 | 01:44 PM
LS1Adam84's Avatar
Yeah it seems to be getting worse it will pop and feel like it is movin around and there is a kind of whine coming from the back left side as well. Well I will be getting it shants shop soon here to get it looked at till then she is getting babied like no other.
Old Dec 26, 2008 | 02:10 PM
LS1Adam84's Avatar
Well the end links didn't look bad when I got the car up in the air yesterday I tightened down everything and it is still doing it... this really kind of bites.
Old Dec 26, 2008 | 02:20 PM
nevrlift13's Avatar
i can hook u up on energy suspension products...hit me up on pm
Old Dec 26, 2008 | 02:36 PM
LS1Adam84's Avatar
PM'd ya.
Old Dec 26, 2008 | 06:38 PM
LS1Adam84's Avatar
Well coming back from lunch it did a nice really loud bang bang bang from the driver side rear, i was going in a straight line and put my foot into it a little and man it was loud, so whatever my issue is it is something either bound up or just getting torqued to hell. mannn maybe I should just wait for it to break then find out what the problem is. hahaha. bad idea I know.
Old Dec 26, 2008 | 07:06 PM
jsteele90's Avatar
is your torque arm tight on the rear end?
Old Dec 26, 2008 | 07:18 PM
LS1Adam84's Avatar
I checked it and it seemed pretty tight. I am wondering if it isn't worn, cause it really started doing this after i took it to irwindale and then did a little foolin around on the street.
Old Dec 26, 2008 | 07:40 PM
ZexGX's Avatar
Sure it's not a loose exhaust component?
Old Dec 26, 2008 | 07:45 PM
LS1Adam84's Avatar
nahh exhaust is up and snug, like I said it was only doing this one left or right turns and you feel it on the driver side, and it feels like the rear is hesitating and it pops and bangs like metal on metal. no constant grinding and this time was just a straight line, it was like a back fire bang but a metal bang. and the rear felt not so good when it did that.
Maybe its a damn unicorn in my transylvanian transaxle.
Zex you think my muffler bearing might be loose?
Old Dec 26, 2008 | 08:21 PM
ZexGX's Avatar
Possibly - did you use the proper washers when retorquing everything?
Keep looking man, check even the things you dismissed or checked before.
Old Dec 26, 2008 | 08:22 PM
LS1Adam84's Avatar
Nope just tightened everything.
Old Dec 26, 2008 | 08:25 PM
LS1Adam84's Avatar
I wonder if my LCA's could be messed up or something? meh probably not ohh well it was way worse this time when I moved my car in the parking lot here at work it was bucking like a mother ******.
Old Dec 26, 2008 | 09:38 PM
jsteele90's Avatar
maybe your posi is taking a dump. my buddys lt1 would buck and jerk when turning and it was his posi that crapped out.
Old Dec 26, 2008 | 10:00 PM
LS1Adam84's Avatar
This would suck hard core, that would explain why it now is doing it in a straight line too. well **** we shall have to see.
