Western Members CA, AZ, NV, UT, CO, NM, HI
Reverse Lights Are Not Working ??? Any Advice ....
Old Dec 30, 2008 | 09:30 PM
F.Rojas's Avatar
Question Reverse Lights Are Not Working ??? Any Advice ....
I noticed the past month or two, when i put my car in reverse the lights wouldnt light up. So i would put my car in neutral and put it back in reverse after 2 or 3 times of doing that, they would come on. Now they wont come on at all when i reverse. I swapped out the bulbs with new ones already and that didnt fix it. Can someone point me in the right direction to get this fixed. Im trying to avoid gettin hit by someone because my lights are not working. thanks
Old Dec 30, 2008 | 10:05 PM
ss.slp.ls1's Avatar
Check the sensor in the middle of the passenger side of the tranny. Check the sensor and the wiring.
beezer1519's Avatar
sounds like its the switch on the tranny becareful... i dont know if its possible but since its not sensing u in reverse the reverse lockout might not work... but i forget if that is related
Old Dec 30, 2008 | 10:08 PM
ss.slp.ls1's Avatar
I don't think that will be a problem. IIRC when you do a T56 conversion, it's common practice to remove the reverse lockout solenoid and block it off with a freeze plug.
Old Dec 30, 2008 | 11:16 PM
F.Rojas's Avatar
thanks for the info gents...will take a look at it in the morning
Old Dec 31, 2008 | 01:39 PM
ROCNDAV's Avatar
Maybe this will help
Attached Thumbnails Reverse Lights Are Not Working ??? Any Advice ....-backuplights99camaro.jpg
Old Dec 31, 2008 | 03:46 PM
eddielb's Avatar
mine started being flaky after I did the 6 speed swap, turned out the backup light switch inside the tranny (where the shifter would hit it) was going out, i just unscrewed the one in there (i think 15mm) and screwed in a new one from autozone http://www.autozone.com/R,2479127/ve...ductDetail.htm 10 bucks later my lights work and everything is good to go
Old Dec 31, 2008 | 03:47 PM
eddielb's Avatar
heres what it looks like
one plug right into it passenger side of the tranny
Old Dec 31, 2008 | 08:05 PM
F.Rojas's Avatar
Cool, thinks for the info...im have to get my car on lift and look underneath. Because my car is too low and it doesnt get high enough with a floor jack. I was trying to look earlier buy my y-pipe was in the way.
