Western Members CA, AZ, NV, UT, CO, NM, HI
99 fuel pump in a 95?
Old Jan 15, 2009 | 12:58 PM
180ls1's Avatar
Default 99 fuel pump in a 95?
The two pumps appear to be different. The 99 pump has a small hose that runs to a bottom filter which the 95 pump does not have. Do i need to get a 95 pump or is there a way to modify the 99 one to work? Do i even need that hose?
here is a pic showing the small dark brown tube on the 99 that the 95 pump does not have.
Old Jan 15, 2009 | 01:02 PM
ss.slp.ls1's Avatar
I would "think" you could find a way to make it work, not sure though. You'd have to find out if that hose is just a breather or something that can be routed somewhere. If you are doing the trap door method, then I would say you could experient if you really wanted to. If you are dropping the tank, then don't waste your time and get the right pump. Don't want to do that twice!
Old Jan 15, 2009 | 01:06 PM
180ls1's Avatar
thanks and ya i am doing the trap door method. But the hose goes to the bottom of the bucket where there is a filter. I am unsure if i can just delete the hose but i dont want to mess something up.
Old Jan 15, 2009 | 01:19 PM
ss.slp.ls1's Avatar
http://www.racetronix.com/RX-F99-FPKG-2.html
Read that, and click where it says "the factory pump...". That little tube is the venturi feed tube which helps keep the bucket filled with fuel, so I'd say it's important.
Here is the tube you are talking about:
http://www.racetronix.com/product/RX...M_top_view.jpg
http://www.racetronix.com/product/RX..._pump-view.jpg
If you were totally in a pinch and had to run the pump, it should work, but if you ever ran low, the bucket could run dry (it would run dry sooner without the tube) and you can burn out the pump.
Old Jan 15, 2009 | 01:22 PM
ss.slp.ls1's Avatar
Any chance you have the '99 bucket as well? Then I think you could use the '99 pump without any issues.
Old Jan 15, 2009 | 01:37 PM
ZSS2148's Avatar
Working lt1 fuel pump....$40
562 704 0353
Old Jan 15, 2009 | 01:49 PM
180ls1's Avatar
ya i have the whole bucket and everything but the tubes to hook it up are different so that would not work.
Old Jan 15, 2009 | 01:50 PM
180ls1's Avatar
562 704 0353
damn, well i just got one from autozone here i think i am just going to install the whole new assembly.
Old Jan 15, 2009 | 01:51 PM
ss.slp.ls1's Avatar
Well I was thinking maybe it was possible to swap just the bucket over. It will have the provisions to utilize the venturi tube so you can use the new pump.
^^^ If not, give Chris a call.
Old Jan 15, 2009 | 01:57 PM
180ls1's Avatar
i will post some pictures up later showing the differences to maybe help in the future. But for right now the autozone pump is going in and i will have peace of mind knowing the right parts are in there. But thanks for your help i appreciate it.
Old Jan 15, 2009 | 02:04 PM
ss.slp.ls1's Avatar
Cool, and with the trap door, you can always throw in a Walbro 255 later down the road.
Old Jan 15, 2009 | 02:24 PM
ZSS2148's Avatar
$50 for the whole assembly. Save yourself some $$!!
Old Jan 15, 2009 | 06:43 PM
59 camaro's Avatar
i bought a lt1 fuel pump off this SOB n i never had any problems with it...worked great
