Ok now im getting pissed the f*** off HELP!!!!!!!!!!!!!
Sounds like the alternator but have you checked all of your connections? Follow both wires off of the battery and make sure connections are tight, also follow the large wire from the stud behind the battery, if its all good then the alternator should be the problem. I was debating on buying an autozone alt because of the lifetime warranty but I think when I checked it was $140, i can get a new delco for $100, looks like im going that route.
so i guess its the alternator that isnt even ****** 5 days old!!!!!!!!!! i drove it maybe 5 miles back to my house and its been parked for 3 days. and these ******* at autozone dont know **** about cars. i mean i dont kno **** either but im not working at an autoparts store pretend to know **** i dont. BUT luckily my good freind just got hired as the manager there. hes a ****** wiz on cars. hes got a fully built 95 turbo supra(biggest turbo ive ever seen in my life). neways he brought out this little meter thing. it was reading that the alt. was pushin out 56 "amps but the batterys voltage was liike 11.01 or some ****. once again i have NO IDEA wat that means. he just said its the alternator. is there a better alternator i can buy? im done ******* wit refurbished stuff. i wouldnt have even purchased it ! if i knew it was refurbished. im not cheap by any means so i duno y they didnt tell me that b4 hand.
edit: P.S. They didn't tell you cause you were shopping at AutoZone.
as for the refurbished thing, i'm pretty sure they just reuse the "shell" of the alternator. so the insides are new.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
ok now this is getting extremely annoying. im 3 minutes away from having someone destroy this car. so i install the new alternator, that i just picked up and had tested b4 i left autozone. it was fine. so i get it in. and the battery meter goes past 13, where its usually at. i close my hood and grab all my tools while i let the car warm up. come back after i put everything away. AND THE ******* BATTERY IS BACK IN THE RED!!!!!!!!!!!!!!!!!!!!!!! WAT THE ****!!!!!!!!!!!!!!!!!!! if i dont have this fixed by monday b on the lookout for the part out of a 00 ss. because im sick of this bullshit. this **** came outta NOWHERE!. if it was my sound system it shoulda done this awhile ago seeing as how ive had the system since ive had the car. this is rediculous. HELP .
#34
#35
I had a similiar problem and it was the battery cables. They looked good on the outside but when I cut the connectors off at the battery the wire was corroded and not making contact inside the insulation to the battery connector.
#36
yesss finally 1 person that this has happend to! lol but im going to try that asap. i MIGHT be getting a job at sears at the auto center part of it so ima need my car. but thanks ima try that...where do i go? autozone? n is the install of that **** easy or a pain in the ***?
#37
Not sure if you already did it but before you go throwing cables at it check the connections. The junction block behind the battery,the ground connections, the connections on the starter, just keep following wires until you find a break, loose connection, or something. If its not any of the wires, not the battery, not the alternator, thats pretty much your whole charging system.
#38
i kno i maybe shoulda posted this earlier but this is wat the battery gauge looks like
![](http://i424.photobucket.com/albums/pp324/yungepjr/photo7.jpg)
but neways itll go past the 13 wen i have sum1 give me juice. itll go right back down to where it is in the pic as soon as i start the car. any pics of where these wires/cables n wat not would be? by the way i appreciate all the help and suggestions
