Western Members CA, AZ, NV, UT, CO, NM, HI
Oil pressure problems
Old Jun 30, 2009 | 02:21 AM
  #41
Revelation Z28's Avatar
Originally Posted by ArticSLPSS
all i really know it was built by LAPD has AFR heads, and a mild cam which im in process of finding which cam it is.
this is the car i passed on then!
was the guy the original owner and had a bunch of pictures of it being delivered and ****?
he had it for sale for 5 months at 9000 then worked his way down.
Old Jun 30, 2009 | 02:28 AM
  #42
ArticSLPSS's Avatar
Originally Posted by 180ls1
do yourself a favor and read through everything in the link i posted, there are tons of different and odd reasons why people lost oil pressure. I would first start out by hooking up a mechanical valve to make sure your car is reading the pressure correctly. If you tear into it there are multiple things you can check so you dont have to keep getting back into it. Good luck
https://ls1tech.com/forums/generatio...sure-idle.html
thanks
Old Jul 6, 2009 | 06:02 PM
  #43
ss.slp.ls1's Avatar
Default Update
So I just replaced the oil pump, oil pick up tube gasket, and cam retaining plate. Oil pressure didn't change much. So I advised ArcticSLPSS to look for a new short block. Ether a new LS1 block or a 6.0 iron block.
Old Jul 6, 2009 | 06:14 PM
  #44
180ls1's Avatar
ugh that sucks
he should grab a 6.0 so he can use the 4" bore.
Old Jul 6, 2009 | 06:35 PM
  #45
LS1BLKSS's Avatar
Banned Village Idiot
hey return that car to the guy you got it from!!!
Old Jul 6, 2009 | 07:06 PM
  #46
ss.slp.ls1's Avatar
Most private seller sales are "as-is". He's **** out of luck...
Old Jul 6, 2009 | 09:51 PM
  #47
LS1BLKSS's Avatar
yea but i think theres still a chance... not sure how many dayz you get tho, might be 3 dayz
Old Jul 6, 2009 | 10:48 PM
  #48
too bad the CA "buyer's remorse" law doesnt help.
Old Jul 6, 2009 | 10:49 PM
  #49
XpEdItIoUs's Avatar
Did you check the welsh plug while the front cover was off? If its not sealing properly the oil pressure will drop due to the oil being drained back into the oil pan.
Old Jul 7, 2009 | 11:11 AM
  #50
ss.slp.ls1's Avatar
It didn't look abnormal at all.
Old Jul 7, 2009 | 11:26 AM
  #51
XpEdItIoUs's Avatar
Did you check the tolerance? I ask because I know he said the engine was built, This plug is removed while machine work is being done to clean out the main oil gallery and it has happend. Thats why some of us add a little bit of insurance to that .
Old Jul 7, 2009 | 11:54 AM
  #52
ss.slp.ls1's Avatar
No I didn't check the tolerance. And sadly the car is all buttoned back up now.
Old Jul 7, 2009 | 01:43 PM
  #53
ArticSLPSS's Avatar
Yeah saving for a 6.0 or 5.7 wish I new this sooner when someone was selling 2 6.0s for like 500 lol right now that same guy has a 5.7 for 450 but said it's dirty n needs a light hone how much that **** cost cause if alot I'm not getting it
Old Jul 7, 2009 | 01:45 PM
  #54
ArticSLPSS's Avatar
Been like 2weeks
