Western Members CA, AZ, NV, UT, CO, NM, HI
Need Help... Same broken Spring AGAIN..!!
Old Aug 3, 2009 | 06:05 PM
09camarossls2's Avatar
Default Need Help... Same broken Spring AGAIN..!!
Its been the 3rd time I broke my valve spring... The scarry part is that i keep on braking the same one..!! I really dont know what it is ... I want to know if anyone knows what it might be..!! Before i start taking more **** apart..!! am not sure of the brand but i got the silver dual springs supposably rated to .650 of a lift....
Old Aug 3, 2009 | 06:19 PM
ss.slp.ls1's Avatar
Maybe your valve stem is bent, maybe a bad rocker arm or bolt, maybe a bad spring seat, retainer, or locks, maybe a bent pushrod...
Old Aug 3, 2009 | 06:34 PM
I compare the pushrod to the other ones it looks good...
rocker arm looks ok too...
Old Aug 3, 2009 | 06:42 PM
SP Motorsports's Avatar
are they rev ? or patriot? patriots will be gold not silver
Old Aug 3, 2009 | 07:14 PM
Soul TKR's Avatar
it's gotta be in the valvetrain... take the valve cover back off, pull the rocker, pull the pushrod... check them over real well. If you can't see anything there, you probably gotta pull the head and start looking at the valves, and maybe even the lifters?
Old Aug 3, 2009 | 07:17 PM
ss.slp.ls1's Avatar
Or maybe a leak down test could tell you if you had a warped/bent valve. Not sure, just throwing that out there.
Old Aug 3, 2009 | 07:39 PM
Raptor_WS6's Avatar
ben...
Old Aug 3, 2009 | 09:01 PM
Wicked94Z's Avatar
no ****** way man!!!!!!!!!!!
Old Aug 3, 2009 | 09:21 PM
SUCK MY SS's Avatar
what type of retainers... floating valve can beat up a titanium retainer quickly... when you remove the valve spring assembly, check the underside of the retainer face for excessive wear...may be an issue where the retainer is not allowing the valve spring to rotate in the spring cup, and harmonics are beating it to death..
could also be a worn valve guide allowing the valve to rock. but usually if that is the case the valve wont have a good seal on the seat..
Old Aug 3, 2009 | 10:55 PM
O.K Guys I have my **** taken apart..... I checked for Push rods, Rocker arms, retainers look good and locks..... My valve stem is not bent but... Theres this blue i would say it looks like an o rig that goes around the botom of valve stem stretch out... wont go back in place...!! maybe a seal.....? ?? idk.. wouldnt think how that would get me a broken spring... but who knows..
Am starting to think it might be a lifter or something..... wouldnt know untill i pull the head off..!!
It happens everytime i **** arround and give it high rpm afther 2 or 3 good pulls... then am driving normal and in a day or two my car starts missfiring... i take the vale cover off and the same broken spring..!!
Do you guys think it might be a lobe on the cam..???
Old Aug 3, 2009 | 11:03 PM
SUCK MY SS's Avatar
can you take a picture of the valve stem seal?
Old Aug 3, 2009 | 11:16 PM
yea... I will..
Old Aug 3, 2009 | 11:26 PM
JJsQwuik's Avatar
Fucken Benji, I told you just buy some 243's and get rid of those old *** 853s.
Old Aug 4, 2009 | 12:31 AM
Raptor_WS6's Avatar
hey ben, get the patriot gold spring kit i told you about, replace all the srpings, retainer, etc..
Old Aug 4, 2009 | 01:16 AM
Hey gilbert I dont think is the springs.... I keep braking the same spring over and over.. I think if i put a dual gold spring or anything else... watever i replace it with ill still barake it..!! i think is something with the valve or a lifter....??
Old Aug 4, 2009 | 01:17 AM
Raptor_WS6's Avatar
is it the same valve that kissed the piston the first time?
i told you, buy hardened pushrods also
one way to check the valve is to pull the head...
Old Aug 4, 2009 | 01:59 AM
Na.... That was the 1st time(passanger side) i ever broke a stock spring with the stock cam...
but know is the other side..(drivers side).....
I know.... I dont want to have to pulled the head off.. so i might just replace it one more time.... and not rece the motor again... baby it... till i get some money... to fix it right... u know find out the real problem..!! by a new gasket re-sufrace the head... ect...
Old Aug 4, 2009 | 03:57 AM
94'BLKBRD's Avatar
L O ******' L
Old Aug 4, 2009 | 11:11 AM
ss.slp.ls1's Avatar
Fixing it now will probably end up saving you more money in the long run. I'd pull the head. No better time to install some 243's.
Old Aug 4, 2009 | 01:40 PM
C5natie's Avatar
Did they machine your heads? Do you use valve shims? Your getting coil bind somehow where the spring is too short. Valve stem, pushrods and rockers wouldnt cause that. Its something where the spring sits or how it was installed. Check all your spring heights.
