Question?
First of all, straight water cools better than a mixture of coolant and water. Second it's a pressurized system, which raises the boiling temperature, that's why the water/coolant doesn't boil. You can run the car on straight diluted water if you want to (not recommended because you'll likely form rust) I have been running on straight water for 6 months because I'm too lazy to drain the system and refill it with a coolant/water mixture.
it could happen...
