Western Members CA, AZ, NV, UT, CO, NM, HI
windshield washer reservoir delete?
Old Sep 14, 2009 | 09:06 PM
hlaalu's Avatar
Default windshield washer reservoir delete?
I never use the fluid to clean my windshield anyway, is it hard to get rid of the reservoir?
Old Sep 14, 2009 | 09:13 PM
-98-Z28-Darkness-'s Avatar
my bro did it and took off the plastic behind it looks like there would be a lot better airflow thought the radiator now. i forgot how it took it off tho think he just had to pull the tabs on the front bumper to give him some room to squeeze it out.
Old Sep 14, 2009 | 09:17 PM
hlaalu's Avatar
Yea that is what I am thinking, it looks like it blocks a large part of the airflow heading to the radiator
Old Sep 14, 2009 | 09:19 PM
hitmanws6's Avatar
im interested in doing this as well. ive used my wiper fluid twice in 2 years. it should save 10-20 pounds as well
Old Sep 14, 2009 | 09:26 PM
tripblackls1's Avatar
i would leave the plastic in front of the radiator all of your airflow comes from under the car that is push up by the diffuser and work very well as it was designed, i think removing the plastic would actually cause a drop in airflow
but as far as the wiper tank its really easy to remove, and pretty strait forward
Old Sep 14, 2009 | 09:28 PM
SoCal01z28's Avatar
I pulled mine off when I removed my front bumper support, so the bumper was already off. You'll never need to use it until its gone...
Old Sep 14, 2009 | 09:37 PM
hitmanws6's Avatar
are you saying removing the tank would hurt airflow? or removing the air dam
Old Sep 14, 2009 | 09:44 PM
XpEdItIoUs's Avatar
I forgot how I removed mine it was years ago.
Old Sep 14, 2009 | 09:46 PM
masterz28's Avatar
He means the plastic shield behind the Reservoir, I took the top bracket off and it came out. Pretty easy, I dont know how to delete the wire that leads into it so I will lurk here until someone sheds light.
Old Sep 14, 2009 | 09:47 PM
hitmanws6's Avatar
worst case you could just hack the hell out of it and when you get enough of it cut you can reach in and unbolt what holds it in and it will be out
Old Sep 14, 2009 | 09:55 PM
XpEdItIoUs's Avatar
A sawzall works wonders for removing car stuff you don't need anymore
Old Sep 14, 2009 | 10:20 PM
hlaalu's Avatar
haha yea!
I'm going to take it out tomorrow I'll let you know what needs to be done. I'm guessing we have the same unit for the most part. I mean hell, they used the same window motors for 15 years
Old Sep 14, 2009 | 10:21 PM
the air dam
Old Sep 14, 2009 | 10:24 PM
hitmanws6's Avatar
haha yea!
if you see a reduction in temp readings i will go ahead and do it.
Old Sep 14, 2009 | 10:29 PM
hlaalu's Avatar
hmm well i am doing a ram air as well so my results won't be accurate
Old Sep 14, 2009 | 10:42 PM
hitmanws6's Avatar
ill do it anyways lol. let me know how hard it is.
Old Sep 14, 2009 | 10:44 PM
XpEdItIoUs's Avatar
what ram air kit do you have?
Old Sep 14, 2009 | 10:46 PM
hlaalu's Avatar
will do!
i'm actually sort of making my own, like this one
https://ls1tech.com/forums/drag-raci...2bu-setup.html
to be honest, i'm really not trying to gain any power, just trying to get some colder air into my car. it was running really hot at the track last week.
Old Sep 14, 2009 | 10:48 PM
XpEdItIoUs's Avatar
will do!
Thats a good choice and cheaper too.
Old Sep 14, 2009 | 10:52 PM
hlaalu's Avatar
Yea people seem to be really happy with the results, it looks like a nice design.
