Western Members CA, AZ, NV, UT, CO, NM, HI
i need thehelp of u 3rd gen guys info please
Old 10-17-2009, 07:43 PM
droptopT/A's Avatar
Default i need thehelp of u 3rd gen guys info please
i am buying a 88 irocz camaro convertible with tpi and a 5 speed mannual trans black paint black top
i have the vin number can anyone run it 4 me or tell me were can i check the vin to make sure its a original irocz convertible tpi 5 speed car
the owner claims the car is original but has no rear disc brakes or iroc z hood 4 some reason or other
it does indeed have the tpi and the 5 speed
i want to make sure it is before i buy it thanks
the vin is 1G1FP31F6JL167241
Old 10-17-2009, 07:59 PM
carbonfiberbird's Avatar
Is it a 350 or 305? What gearing does it have?
Old 10-17-2009, 08:02 PM
droptopT/A's Avatar
i dunno the owner claims its a 350 5.7 tpi 5 speed.gearing i duont know
Old 10-17-2009, 08:04 PM
Well 350's dont come with 5 speeds, they made too much torque for the tranny to handle, so it probably not an original but still thats the set up I would want. If its a good deal I would still pick it up. What condition is it in? and how many miles are on it?
Old 10-17-2009, 08:20 PM
droptopT/A's Avatar
ummmyeahh i might still get it but i wanted original iroc z
Old 10-17-2009, 08:39 PM
z28gsxr's Avatar
350's didn't come with convertibles either. Its possible that it can be an iroc with rear drum brakes but it should still have an iroc hood. Go to www.thirdgen.org/techboard in the history section and post your question. Also list the first 8 numbers of the vin and they'll decode it for u.
Old 10-17-2009, 08:44 PM
topfig1's Avatar
Nope, 5 speeds came with 305's exclusively. I've owned five of them. The 5.7's came with 700R4's only despite what anyone tries to tell you. That was my biggest complaint, I wanted a 350 with a 5 speed.
TopFig
Old 10-17-2009, 08:46 PM
TPI TERROR's Avatar
if the 8th digit is a f. originally its a 5.0
if its a 8 is a 5.7
Old 10-17-2009, 08:51 PM
Here's what you need to know
http://www.thirdgen.org/1988-chevy-camaro
That would be awesome tho if it were a 350TPI 5speed, **** throw some gears on it and that thing will be pretty quick. If you do get it and it is a 350 than be easy on the trans. those t5's dont hold up to too much more power that what they are rated for(300LB torque)
Old 10-17-2009, 09:18 PM
wickedbluess's Avatar
if its a 8 is a 5.7
That's good info. Thanks
Old 10-17-2009, 09:21 PM
Now you have my attention
GTOSE's Avatar
Any pictures? G92 code would indicate that it has disk brakes which are garbage anyway. If you do end up getting it try and invest in a 1LE setup.
Old 10-17-2009, 09:45 PM
Jeremy 92 RS's Avatar
The car was originally a 305, the "F" as the 8th digit of the VIN tells us that. You can also check to see if the car was indeed originally a manual transmission by looking for the RPO code "MM5" which will be in the glovebox I believe, in an 88. That sucks about the hood, but more than likely it was in a wreck or something at one point and someone probably put on a standard RS/coupe flat hood.
The older pre-89 rear disc brakes were not so hot of a setup, but the disc brakes that came stock on any 89 and up 3rd gens were the same ones that 1LEs were equipped with. They were the PBR aluminum calipers.
if its a 8 is a 5.7
I know that TPI TERROR knows this, but keep in mind that those digits are referring to TPI motors only. There are other codes that do designate other motors with other types of induction systems.
Old 10-17-2009, 11:56 PM
GTOSE's Avatar
You are correct, 89 + brakes are brilliant.
Old 10-18-2009, 01:21 AM
droptopT/A's Avatar
thanks guys for the help i might still get it just cause its a v8 and a vert 5 speed
Old 10-18-2009, 01:27 AM
Yeah if its a good price and the car is not completely thrashed, fo sho. Vert + T5 + 3rd gen = rare
Old 10-18-2009, 02:04 AM
droptopT/A's Avatar
there asking 2,500 but it needs some work to pass smog and has no exhaust besides that i was told it runs fine and has alotof power
Old 10-18-2009, 11:35 AM
z28gsxr's Avatar
Make sure it is a 350 since its real common with third gens that they tell u that it had a 350 swapped in and come to find out its a 305. For the price i'd buy it though
lowerthanyou00's Avatar
sounds like a good deal we got this one for 1700 but it didnt run and it only had a tbi auto. but with intake gaskets it ran and after we drove it we pulled that pile out and put a real engine in. https://ls1tech.com/forums/conversio...swap-pics.html
Old 10-18-2009, 11:40 AM
FBDYLVR's Avatar
Again, with the F as the 8th digit in the VIN it is a 305 TPI motor. Unless someone pulled the block and replaced it with a 350, treat it as it were a 305.
Old 10-18-2009, 10:02 PM
droptopT/A's Avatar
well i dont think ima buy it no more after talking more to the guy whos selling it he said it was wrecked from the front thats why it has no iroc hood and he also said its missing exhaust all of it.its missing the speedometer cable has the check engine light on and the rear end has been swaped to drums weird its a 3 hour drive so i might just keep looking 4 one closer to home
what do u guys think
