my fukn third gen :(
#81
who lives in oxnard.
i found a 350 tpi there that for the price sounds resonable an the engine looks good
seems like the guy was building it..
i cant put the link rite now since im at work an doesnt allow me to get on there...
i was wondering if maybe someone lived very close to there if maybe they could check it out for me...
i really need to get my **** back up an running...
#82
Step 1) borrow a buddies pickup. price- a case of beer.
Step 2) come get jason's engine and transmission. price-gas money ($150?) plus price of engine and tranny=$1650
Step 3) buy some thirdgen headers and exhaust. price-about $1000
Step 4) have it all installed. price-free if you know the right people.
So in short for between $2500 and $4000 you'll have a badass, lower mileage setup that will beat stock ls1's. To me this is a no brainer. Get your *** over here and pick it up.
i would love to do this but i dont have anyone that can help me do all of this...
plus don't i have to do more mods on it such as fuel an **** like that
#83
Its actually a very straight forward swap. You would swap in the LT1 just like you would any other motor. No need for special motor mounts or anything. Your car was a TPI car from the factory so you can use the stock fuel pump, the only things that need to be compensated for are the fuel lines under the hood and the power steering lines and reservoir which are easy as hell to make with parts from Auto Zone, OR there is a guy on thirdgen.org named z28ricer that sells customized parts for the swap ready to go.
#85
I figured 1500 is what I want to get for it.
Will come with wire harness and PCM tuned by Madtuner
Bad: Engine is pretty greasy, once it's out you can clean it up, and reseal anything you want.
LT1
~45k on the bottom end
stock heads and intake
CC503 cam
Crane 10308 dual springs
Comp Pro Mag 1.6 rr's
TF guideplates
ARP rocker arm studs
PS painted 1 3/4" LT headers (a bit dinged up since my car is slammed, but you'd need different headers anyway)
Prof Prod 52mm TB
Cobra 39# injectors
T56
~175k miles, no problems
newly installed Zoom kevlar clutch
stock slave and master
stock shifter, hurst pistol grip handle
LT1
CC503 cam
TF guideplates
Prof Prod 52mm TB
Cobra 39# injectors
T56
could you post some pics up of everything
#86
Jason's setup hasn't been dynoed but he's probably pushing around 350 rwhp.
The t56 swap would be cake in your car because it's already stick. You'd have to make a small lil custom bracket i think for one of the pedal's and possibly a shorter driveshaft which isn't a big deal..someone else should confirm this though. Read up on thirdgen.org also.
#87
#88
so i wouldnt have to shorten the shaft...
what about all the wiring???
how come the engine an the t56 have diff miles do you guys kno..
the lt1 says 45k an tranny 175k...
#90
#92
oh... well im really interested in this set up to get my car up an running hopefully it will be bad ***...
i started doin all my body work on it already getting ready for primer...
how far is it from vegas were you guys or he is located at
#97
If you're starting off with a TPI harness it makes it easier, but there is still a lot of splicing. And if you do it this way it will be harder to pinpoint little problems down the road if you get any. If you can afford it, you're better off just going with a custom harness if you're not good with wires and tinkering. Not the cheapest route, but its the more painless way to do it. These harnesses are usually in the range of $400-$500 depending on the company though.
