Western Members CA, AZ, NV, UT, CO, NM, HI
I cant figure out whats wrong...
Old 12-01-2009 | 02:51 AM
99sscmro's Avatar
Question I cant figure out whats wrong...
So this past weekend i decided to throw on a eibach prokit that i had bought a couple of weeks ago on my car (99 ss) i started with the rears and lowered it to install the fronts. But i noticed that the rear drivers side was lower ( and it still is ) than the passenger side. Does any 1 have an idea why? I havent installed the front ones yet, so the front is stock springs with i believe kyb struts. Any input on this would be great, thanks guys!
Old 12-01-2009 | 02:54 AM
JeaneZ28's Avatar
I forget what they call it exactly but there is a cup that goes on the top of the spring. Is the cup seated correctly on the spring.
Old 12-01-2009 | 02:57 AM
99sscmro's Avatar
Yeah its on there correctly i took them off like 3 maybe 4 times and switched them around just to make sure and still the same thing.
Old 12-01-2009 | 02:59 AM
JeaneZ28's Avatar
Have you tried driving it yet? Sometimes it takes a drive to get them to settle properly.
Old 12-01-2009 | 03:08 AM
uLs1a's Avatar
Its ok, my car does it to and I have the Prokit. Do a search about your car leaning there are about 15 different threads about it already.
Old 12-01-2009 | 03:27 AM
99sscmro's Avatar
My 315 35 tires rub also, is there anything that can be done to fix that. New shocks maybe? or roll the fenders (rear)
Old 12-01-2009 | 03:28 AM
99sscmro's Avatar
Yeah i drove my car sunday and today to and from work and it sits the same.
Old 12-01-2009 | 04:15 AM
lowerthanyou00's Avatar
ur might have to roll the fenders, check ur trans mount been known to cause the car to sit sidewayz. otherwise if its about an inch on difference side to side its normal haha, even my stock springs are like that and a couple friends i know with prokits same thing. dont really notice tho till it gets low.
Old 12-01-2009 | 04:42 AM
99Bluz28's Avatar
Are both(left & right) of the spring pigtail ends pointing in the same direction(towards the rear of car).
You need an Adjustable PHB to recenter the rear after lowering.
Old 12-02-2009 | 10:50 AM
The Double S's Avatar
The car being tilted because of lowering is normal. A lot of people have that. You probably have to roll the fenders if the edge of your fender is rubbing on your 315s. If your tires are rubbing on the inside of the fender, you have to get a big hammer and pound down the areas inside your fender where they are rubbing. On here they refer to it as the "BFH mod." If you're running 10.5s or larger in the rear you most likely have to do that.
Old 12-02-2009 | 11:45 AM
hlaalu's Avatar
you could add the hose mod on the low side, that will pick it up slightly
Old 12-03-2009 | 12:19 AM
djsanchez2's Avatar
My SS had the infamous tilt going on too I ended up removing one of the spring pads completely and it leveled itself out. Some are just crooked from the factory man, sucks but its true. Some have even gone as far as to blame it on the weight of the spare tire/jack. Take it out and see if it levels out for you...
Old 12-03-2009 | 01:35 AM
99sscmro's Avatar
hmm ill do some research on that one thanks man
Ok ill look into it some more thanks bud
Yeah imm a have to roll the fenders, its not really that bad but i noticed a diff on the tires when i used the car after the drop. Yeah my wheels are 11" wide so some pounding is gonna come into play thanks for all the help. From everyone.
Old 12-03-2009 | 01:43 AM
99sscmro's Avatar
Im going to have to look into that cuz its driving me nutz.
I know for sure i located the springs the same direction but i faced the pigtails facing the tires though.
Before the drop i really didnt pay any att to the diff in height. So maybe if i go with a different setup or would it be the same if i were to go with another spring and strut,shock's.
Quick Reply: I cant figure out whats wrong...
