lt1 formula help smells like gas inside
hey guys i just bought a 94 lt1 formula car and when i am driving it starts to smell like gas i changed the gas cap thinking it was the problen since the gasket was brittle but that wasnt the problem. what could be causing this it gets kinda hard to drive it smells like gas or exhaust fumes any one had a similar experiance i am kinda a newb to lt1 any help would be apreciated thanks in advance
hey the o ring around the fuel pump module i would have to drop the gas tank to check huh whats the evap purge canister and were is it located how can i check this hahaha sorry i ask alot of questions
ima check it out tommorrow
evap canister is on the driver side inner quarterpanel, in the rear of the wheel well. its just a plastic cover that hides it. but that is just the canister. i would check all lines going to it from the tank, then from the canister to the solenoid, then intake manifold vac. port.
i would check the tank last, since it takes the most work accssing the connections/module. the o-rings are not that common to crap out, but if the module has been removed at any point for a pump replacment or part service, it may have been installed incorrectly.
either drop the tank or cut a hole...
thanks i will check it tommorrow aso could it be that is running rich when i rev it up it pops a little also the gas smell is pretty bad makes the eyes all watery lol i checked the maf and it has been descreened i once read that it could cause it to run rich also. the car is bone stock no intake not even a knn filter only mod it has is descreened maf and a flowmaster thats how i got it
thanks guys for all th help i figured out the problem.
the problem was the fuel pressure regulator was missing the hose that connects to the intake and the intake was blocked with a plug i am going to fix it right tomorrow
yeah when i bougth the car it didnt have the vacumm line connected to the regulator and the intake was blocked of with a plug i just bought a brand new napa fpr ima intall it today i already went threw 4 full gas tanks lol in 1 week.the only thing i am missing is the vacumm line anyone got one for sale
