any ideas on how to get some mpgs
car is getting way better mpgs after changing out a leaking fpr and reconection a vacumm line but there is still a gas smell coming from the rear driver side quarter panel how exactly do u check the evap canister
BS. i've driven my car WOT an entire tank of gas practically and then the next kept the rpm's less than 3k (i have a manual) and the mpg was exactly the same. and by "exactly the same," i mean i didn't measure the .x in the number, but it was 17.x in both instances. maybe i have a weird ls1, but i don't think how i drive has ever made any difference at all.
#38
Read this article: http://money.cnn.com/2005/09/01/Auto...test/index.htm
and this article:
http://money.cnn.com/2007/05/09/pf/gas_myths/index.htm
This is true on level ground. I wish I had cruise control because it is far better at precise RPM/MPH changes on flat ground than my foot is.
Nope. That only makes it idle which eats MORE gas. There is a function called Decel Fuel Enleanment that GM has been using for a long time. It is used in our cars for sure.
and this article:
DECEL FUEL CUTOFF – Decel fuel cuttoff means exactly that. When you take your foot off the gas pedal going downhill or decelerating quickly, the ECM will cut off the fuel entirely. The difference between this term and the next one, DECEL FUEL ENLEANMENT, is that some fuel is allowed to reach the engine during DECEL Enleanment. As to when one or the other occurs, I don't know. I do know that on my TPI system, I noticed a lunge from the engine right around 1500 RPM, so I think this is where the DECEL fuel enleanment takes over from the DECEL FUEL CUTOFF. The lunge was significant and could easily cause you to run into the something if you weren't expecting it. I also believe a speed sensor is required for these two modes to operate period. So this is another reason to have a speed sensor.
