Western Members CA, AZ, NV, UT, CO, NM, HI
SOMEBODY CLIPPED MY REAR-END!!!Need Help!!
Old 06-21-2011, 03:36 AM
HoosierDaddy?'s Avatar
Default SOMEBODY CLIPPED MY REAR-END!!!Need Help!!
Somebody clipped the rear driver quart panel of my car my car pretty good..enough to spin the car 180degrees.The car shut off an won't start now.Any Suggestions on why?
Old 06-21-2011, 03:57 AM
kmracer's Avatar
fuel pump safety switch. do a search.
Old 06-21-2011, 09:23 AM
mannyman84's Avatar
I don't think these vehicles have a safety switch. What year is it?
Old 06-21-2011, 12:34 PM
Its a 2002 Z28 35th aniversery
Old 06-21-2011, 01:30 PM
XpEdItIoUs's Avatar
F-bodies do not have an inertial switch.
Old 06-21-2011, 03:53 PM
I pulled the relays to the fuel pump and pcm an still got nothing...with a few cranks to try n start it the battery went dead?...what's goin on?
Old 06-21-2011, 03:54 PM
xxrillixx's Avatar
Does the car try to turn over? Or does it not crank at all?
If you dont get power or it doesnt crank... Check the fuses, if your battery holder is broken like every fbody ive seen your battery could have easily grounded and blown a fuse or even the ECU.
If you get power, and it does crank, check the wires around the rearend (look where the rear seats are, but on the outside, follow those lines to the pump)... especially if you were hit on the drivers side... Make sure the fuel lines and wires are not damaged or pinched.
Old 06-22-2011, 02:46 AM
It cranked an tried to turn over but about 20mins after the accident the battery was going dead but even when there was juice it wouldn't turn over...but that's first on my to do list for 2marrow morning.I really appeciate the help I'm getting cause I really need to get her back on her feet.its a mint condition 2002 Z28 6spd with 53k ORIGINAL miles! I purchased it from an older woman who just happens to be the FIRST owner! An never let another under the hood,always took it to rydell for its reg maintn and tune-ups!! I guess that's why its hurtin me so much to see her like this :/
Old 06-22-2011, 10:48 AM
xxrillixx's Avatar
Yeah, I hear ya. Hopefully insurance will take care of you... but they total these cars for the smallest damage. Only thing that might save you is the low mileage.
Keep posting up with what you find!
Old 06-22-2011, 11:11 AM
Colemann's Avatar
Is it possible you damaged the fuel line??
Old 06-22-2011, 04:00 PM
Possibly...I didn't have time this morning even tho I should of made it my priority! But its a for sure thing 2marrow.
Old 06-23-2011, 06:30 AM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Thumbs up
Actually if any of the vehicles "air bags" deploy, the vehicle is considered totalled (insurance company wise). If this occurs, and you feel that you can fix the vehicle, you can purchase it back (after payout) with a new "salvaged" title.
SteveC
Old 06-23-2011, 01:38 PM
xxrillixx's Avatar
Definately true, but Ive yet to get an fbody where the bags were deployed. And they all have been drivable, literally turn key and go.
Old 06-27-2011, 04:16 PM
no bags deployed...but i checked the fuel lines an electrical wires goin to the fuel pump an they are all intact an connected.Im hearing these cars came with a safety feature incase of an accident when hit from the rear end the fuel pump automatically "kills itself/shuts down" permanently?
Old 06-27-2011, 04:59 PM
xxrillixx's Avatar
With a good battery....
That should be easy to test... does the car prime when you key on? (can you hear the pump)
Do you have fuel pressure? if you dont have a gauge to test it, pull off the cap on the drivers side fuel rail, put a bottle or something to catch the fuel... and try to start the car. If there is fuel coming out you have fuel pressure. it wont be a whole lot, but there should be some fuel coming out.
If you have fuel pressure... And the car is turning over but not starting, try replacing the starter and ignition relays under the hood. They are like $12 a piece. (id just borrow a set from a friend for 5 min and see if it works)
If That still doesnt work you need to get a noid light to see if your getting spark.
If you still dont have spark I would check the cam position sensor and crank position sensors... You might have to get a code reader to see if either of those are faulty.
Other then that it should start. It may not run well (if something else is wrong)... but it should start.
Old 06-28-2011, 03:06 PM
I have noo fuel pressure...pulld the cap an turn key t on position an heard the fuel pump but very dull an low..but not one drop of fuel came out
Old 06-28-2011, 03:13 PM
But jus now when I turn key to on position without tryin to start it a few times to let the fuel pump prime it starts to turn over but won't turn all the way
Old 06-28-2011, 08:03 PM
pweterss's Avatar
could be a loose ground somwere with a power tester check all the vital power connections
Old 06-29-2011, 11:15 AM
Besides having a loose ground...could the fuel pump have gone bad on impact? Cuz I can still hear the pump turn on but its a very dull,low-pitched humm,not as loud as it was before
Old 06-29-2011, 11:19 AM
henry172's Avatar
Put a fuel pressure tester on it and see what your pressure is.
Quick Reply: SOMEBODY CLIPPED MY REAR-END!!!Need Help!!
