Oil pan gasket!!!!!
#34
Honestly the best way to change the OP gasket in my opinion is to just pull the motor because you will always find somthing else like a bad motor mount, rear main seal etc, pulling the motor from the top or bottom is not all that bad, having the right tools is the key here.
