Western Members CA, AZ, NV, UT, CO, NM, HI
Slave Cylinder question!!!!!!!
Old Nov 10, 2011 | 10:38 AM
1sick68's Avatar
Default Slave Cylinder question!!!!!!!
So I'm doing the clutch on my ls1 and I want to replace the slave cylinder. My question is how do you remover it, and what's a good replacement brand! Any info will help thanks!!
Old Nov 10, 2011 | 02:18 PM
ConElite's Avatar
go with a stock GM unit from a post 2001 F-body. Drop the trans and 2 10mm Screws hold it in place. Hardest part is removing the hydro line.
Old Nov 10, 2011 | 02:25 PM
98BLOWNZ28's Avatar
what he said. the hardest part is disconnecting the master cylinder line. why are you replacing the slave?
Old Nov 10, 2011 | 02:28 PM
ConElite's Avatar
2 little flat heads. one on each side to push in that white tab and PRESTO!
Old Nov 10, 2011 | 03:13 PM
sic7camaro's Avatar
or u can use a clutch pedal bushing if it doesnt have the white tab.
Old Nov 10, 2011 | 11:16 PM
1sick68's Avatar
thanks guys.. i will use these instruction to my advantage!! and im going to replace it because it was leaking..
Old Nov 13, 2011 | 05:59 PM
SS#2906's Avatar
The Ram Hydraulic unit is a very good replacement, however not cheap.
Biggest pain is the adjustment, but has proven to be a great unit for me. I combined it with the tick master and have NO issues shifting at all.
http://ramclutches.com/Products/stre...se_bearing.htm
Old Nov 13, 2011 | 11:13 PM
henry172's Avatar
Have you done the drill mod if not it might be something to look into.
Old Nov 15, 2011 | 08:27 AM
Joey@Tick's Avatar
LS1TECH Sponsor
We always suggest sticking with a GM Replacement slave cylinder, we ever designed our Adjustable Master Cylinder to work with it: http://www.tickperformance.com/gm-sl...or-ls1-f-body/
