Western Members CA, AZ, NV, UT, CO, NM, HI
Notching motors.
Old Jul 25, 2012 | 08:33 PM
Chuchin2o9's Avatar
Default Notching motors.
Does anyone know of a good place in the central cali area where I can get a motor notched , honed and all?
Old Jul 26, 2012 | 08:16 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
notched? like clearancing for a stroker crank?
Old Jul 27, 2012 | 05:04 PM
Chuchin2o9's Avatar
Yes I will be getting a lq4 and I want to make it into a 418 stroker but I don't know of a place that will do a good job and I want to see how much it'll cost.
Old Jul 29, 2012 | 01:57 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i would not go longer then a 4" stroke on a lq4 block, the sleeve legnth is too short therefore the oil rings tend to come out the bottom of the sleeve , which can induce oil burning...
Old Jul 29, 2012 | 02:59 AM
Chuchin2o9's Avatar
Is there any way around that. I was going to get the rotating assembly from texas speed. The 418/421 lq4/lq9. But if its too big I think there's a 390 or something like that.
Old Jul 29, 2012 | 03:10 AM
oChristiano's Avatar
You could go 402/408..
Old Jul 29, 2012 | 03:21 AM
Chuchin2o9's Avatar
If I go 402/408 would I still have a problem with the rings slipping off?
Old Jul 29, 2012 | 09:29 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
no you are good, i build 408's all the time... its a 4.030" bore( stock bored .030" over) 4" stroke
Old Jul 31, 2012 | 06:18 AM
Chuchin2o9's Avatar
What would a 418 be , like 50 over?
But what should I be looking to pay in order to get a motor stroked and getting the new rotating assembly installed.
Old Jul 31, 2012 | 11:34 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
believe .060" over is 414... no real point in boring it that far over no reason...
likely pay around 3500 for quality components, machining and assembly.. not including the block
Old Jul 31, 2012 | 03:10 PM
Chuchin2o9's Avatar
Well I was planning on getting the rotating assenbly from texas speed and then taking it in with the block. All I'd need them to do is all the machining and installing the rotating assembly
Old Aug 3, 2012 | 04:38 PM
ZexGX's Avatar
Machining and assembly at a quality shop is gonna be at least $1200 unless you have hook-ups. Key word being quality. I can slap everything together for you for $200 if you want to save money. No warranty though and the cell phone number I give you may or may not be from WalMart. $3500 is about right for a proper forged rebuild in this case.
